Hello,
I've been trying to migrate from Vista 32 (which worked ok, minus major issues with my Motif ES6 MIDI input and hardware/buffer issues). I recently partitioned my O/S hard drive to create an O/S partition specificially for Pro Tools. I did a fresh installation and reinstall of Pro Tools 8.0.3 (I did not turn on my hardware), and then the 8.0.4 update. I then installed all my other soft synths to the O/S, and all soft synths samples to a secondary hard drive. I am running into problems when attempting playback using my softsamplers (Omnisphere, Kontakt 4.1) within Pro Tools 8.0.4. Playback will freeze and the computer will lock up. A hard reboot is then required. My hard drive setup is as follows: -Primary internal Western Digital Black 1TB SATA6 7200 RPM, partitioned to contain two Windows 7 x64 O/S installations, one partition for non music work, and one installation specifically for Pro Tools. - Secondary internal Western Digital Black 1TB SATA6 7200 RPM. All samples are installed to this drive (Kontakt 4, Omnisphere, Stylus) - ESATA SATA3 Hitachi 7200RPM. All Pro Tools recording is done to this drive. All Pro Tools projects are saved to this drive Based on my research within this forum and AVID's kb, I've already tried the following: 1. Disable Wireless 2. Disable DEP 3. Update nVidia drivers (to driver date 6/7/2010 version 8.17.12.5721) 4. Updated PACE drivers (most recent x64 PACE drivers from ilok website) Other notes: - I'm using an ADS PCI firewire card as recommended by AVID. The firewire controller is using a Texas Instrument chipset. I've disabled the motherboard's onboard Firewire port. - I've set the Pro Tools LE shortcut to always run as administrator. Any help is greatly appreciated. Thanks. -J Here is my Sandra Soft info: SiSoftware Sandra Computer Model : HP-Pavilion KJ382AAR-ABA m9250f Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz Speed : 2.67GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : PEGATRON CORPORATION Benicia BIOS : AMI 5.32 10/23/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 DDR3 Chipset Model : HP P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Mosel Vitelic (ProMos) V916765K24QCFW-G6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Mosel Vitelic (ProMos) V916765K24QCFW-G6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Mosel Vitelic (ProMos) V916765K24QCFW-G6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Mosel Vitelic (ProMos) V916765K24QCFW-G6 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.75GHz, 512MB DDR2 2x476MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8600 GT (32 SM4.0 1.75GHz, 512MB DDR2 2x476MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8600 GT (32SP 4C 950MHz, 495.6MB 2x476MHz) Adapter : NVIDIA GeForce 8600 GT (32SP 4C 950MHz, 495.6MB 2x476MHz) Adapter : NVIDIA GeForce 8600 GT (32SP 1.75GHz, 495.6MB 2x476MHz) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (C:) (D:) (E:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (G:) Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (M:) Generic USB SD Reader (USB) : N/A (H:) Generic USB CF Reader (USB) : N/A (I:) Generic USB xD/SM Reader (USB) : N/A (J:) Generic USB MS Reader (USB) : N/A (K:) HL-DT-ST DVD-RAM GH10L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 983MB (F:) Logical Storage Devices Hard Disk (C:) : 456GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) WDSamples (G:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) ProTools (M:) : 932GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) OS4ProTools (D:) : 456GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) HP_IMAGE (E:) : 20GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Removable Drive (H:) : N/A @ Generic USB SD Reader (USB) Removable Drive (I:) : N/A @ Generic USB CF Reader (USB) Removable Drive (J:) : N/A @ Generic USB xD/SM Reader (USB) Removable Drive (K:) : N/A @ Generic USB MS Reader (USB) Kontakt 4 (F:) : 983MB (UDF) @ HL-DT-ST DVD-RAM GH10L (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP (ICH9) LPC Interface Controller LPC Legacy Controller 1 : Asus F8000 Audio Device : HP (ICH9) HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : HP ICH8R (ICH8) SATA RAID Controller USB Controller 1 : HP (ICH9) USB Universal Host Controller USB Controller 2 : HP (ICH9) USB Universal Host Controller USB Controller 3 : HP (ICH9) USB2 Enhanced Host Controller USB Controller 4 : HP (ICH9) USB Universal Host Controller USB Controller 5 : HP (ICH9) USB Universal Host Controller USB Controller 6 : HP (ICH9) USB Universal Host Controller USB Controller 7 : HP (ICH9) USB Universal Host Controller USB Controller 8 : HP (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : ADS Technologies TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 |
Lots of Freezing/Lock ups.. please help! | Dopamine | macOS | 8 | 03-21-2014 03:51 PM |
Pro Tools (MP) 9 on Windows 7 keeps freezing | asifkhan88 | Windows | 9 | 10-06-2012 02:33 PM |
Lock Avid Mix to Pro Tools 10 (Windows 7 64) | krazylain | Artist Series | 2 | 03-15-2012 06:43 PM |
Pro Tools Freezing during playback | erictalley523 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 09-25-2009 08:10 AM |
Pro Tools on Windows 98 Freezing! | xlrsound | General Discussion | 0 | 07-26-2004 12:36 PM |
