Old 01-01-2011, 04:13 PM
TuftStudio TuftStudio is offline
Default Music Production Toolkit 2 and PT9?
I'm considering the upgdrade to PT9, I am on PT 8.something now, with MPT2. I see that there is an upgrade offer for the MPT2 to CPTK, but it's a lot of cash, and I really don't need more tracks and that stuff.. What I need is Smack, TL Space and Hybrid, the stuff that I have already bought in MPT2. If I upgrade to PT, can I still install these from MTP2, or is the expensive CPTK the only way to get them into PT9? I have so many projects lying around with those plug-ins, I really can't do without them
Thanks
J-A
-Powermac G5, OSX 10.4.9. Dual 2Ghz, 4Gb ram, 2x internal SATAdisks(software/audio)
-002-rack with Command 8, running PT 7.3.1 cs9 with MPT
Old 01-01-2011, 04:15 PM
Default Re: Music Production Toolkit 2 and PT9?
My signature-info is wrong by the way I'll update it!
J-A
Old 01-01-2011, 05:44 PM
HD2 HD2 is offline
No, you don't need CPTK2. IN fact it doesn't even come with those plugins. You already own them so you would just need to download the MPTK2 installer for V9 and re-insall. be aware though that there is a problem with the installer when installing structure LE. I am still waiting on an update to the installer that i was told would be soon. But who knows how soon.
Old 01-02-2011, 04:24 AM
barlevy barlevy is offline
when you buy PT9 you get MPTK2 installer update
when running this update you just need to remember to uncheck the MP3 option
which is free in PT9 anyway
Old 01-02-2011, 10:59 AM
Thanks so much! Then I guess I should get my ass in gear and get PT9. I use Reason for sampling, so Structure isn't that big of a deal really.
Cool!!!
J-A
Old 01-07-2011, 12:10 PM
priorytools priorytools is offline
I'm in the same situation as "Tuftstudio" with my LE set up. . .
Does the above mean that if you don't uncheck the mp3 option, the installer won't put in the rest of the MPTK2 content ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-07-2011, 06:03 PM
mblanton66 mblanton66 is offline
I have MPTK2 and upgraded to 9. The 'old' installer required PT8 to be installed in order to run. So those starting from scratch with a fresh PT9 install couldn't use it to add the plugins from the toolkit. The track expansion option, as well as the mp3 option, is obsolete (they're included in PT9).
The 'new' installer simply is a single installer for the bundled plugs that does NOT require PT8 to be installed. It's just a convenience, as the separate installers are also located elsewhere.
I uninstalled PT8 and installed PT9. That process didn't touch the bundled plugs (smack, dinr, etc). They were still there and all work just fine.
Only if I reformatted and/or reinstalled the OS, then PT9, would I need the new MPTK2 installer.
Since I didn't use the new installer I can't say how it behaves. If it indeed has a checkbox option for the mp3 (and track expansion) I would uncheck those first. Hope this helps.
Old 01-08-2011, 01:03 AM
sunburst79 sunburst79 is offline
Since the assets are on your iLok I would deep six the MPTK installer and just down load the latest versions of those particular plugs from Avid.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-08-2011, 08:20 AM
Which is exactly what the 'new' installer is, in one convenient package.
Old 02-01-2011, 05:20 AM
Where is that installer to be found ?
[IMG] code is Off
music production toolkit 2 ericlees Pro Tools M-Powered (Mac) 2 11-08-2010 12:28 PM
DV Toolkit 2>Music Production Toolkit nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-11-2010 06:52 PM
DV Toolkit/Music Production Toolkit upgrade price question EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 12-17-2008 05:23 PM
Music production Toolkit kattaman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-19-2007 12:27 AM
music production toolkit chahende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-13-2007 11:56 PM
