Mbox playback issue
I recently fired up my mbox to record a simple session but was very disappointed after recording the first solo track because there was no playback. I could see the pre-fade meter jumping and sending out thru the master fader but all I could hear was the active mic. I toggled between Auto Input and Input Only, alas.. to no avail, could still only hear the incoming signal from my beta 58. From there, I rewired Reason into an Aux track. I can see the drum sample's audio get sent out of Reason, into protools, and out the master but still only hear the live line. I'm assuming it's gotta be a hardware issue but has anyone got a clue on how I may fix this?
Re: Mbox playback issue
Reason should go on an instrument track. Then, you can pick the different modules inside Reason(redrum, combinator, thor, etc) that you want that track to record.
Also, are your tracks record enabled (click on the "R").
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
My guess is it is set all the way over to the input position. Try setting it about 12 o'clock or so.
PT9/W7 Mbox Pro 3 playback issue...DAE -6117??? | wuzlow | Windows | 14 | 07-25-2013 11:24 AM |
mbox 2 pro audio/playback issue!! | 2ooster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-17-2008 12:00 PM |
playback issue in Mbox | trueblue2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-20-2006 04:44 PM |
Mbox Playback issue | cowasoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-07-2005 07:17 AM |
PT/Mbox playback issue...PLEASE HELP! | Danny M. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-21-2003 11:03 PM |
