Old 05-31-2011, 02:41 PM
Ormond Ormond is offline
Default What??? MBox3, 8.05 No Hardware Setup Dialog Box!!
So, MBox 3, 8.05 - I do not get a dialog box when when I select Hardware... from the Setup Menu. Nothing comes on screen. I NEED TO set the S/PDIF option but cannot get to it because this dialog box will not open.
Is this a know issue?
Old 06-01-2011, 12:36 AM
Default Re: What??? MBox3, 8.05 No Hardware Setup Dialog Box!!
I went back to 8.04. I no loner get the "personality missing" prompt box but I still cannot get a Dialog box to come up when I select Hardware under the Setup window. Is this a know MBox 3 issue????? I am using Leopard, not Snow Leopard. does that make a difference?
Old 06-01-2011, 01:06 AM
I went back to 8.0 - I did get a dialog box when I selected Setup>Hardware... but it l;ooked strange and did not allow me to select S/PDIF.
I stepped up to 8.01 and once again nothing happens when I select Setup>Hardware...no dialog box comes up at all!
8.04 - No dialog box comes up
8.05 - no dialog box comes up.
Please, Digi Support - I do not want to have to take the MBox 3 back just because of this. I am on a iMac Dual processor and am running Leopard 10.5.8
Old 06-01-2011, 01:14 AM
I used the Utility Folder panel that came with my 8.04 version and followed the instructions. It did not get rid of the problem.
Old 06-01-2011, 01:30 AM
So, if I access the MBox3 from the System Preferences Menu (get the software Dialog box) I can select S/PDIF tab and I can select S/PDIF in the I/O Mix Window. It is too late to hook up the synth tonight to check out if I get sound or not...
However...Setup>Hardware....from the Menu up top I still do not get a Dialog Box to open. Is there no such thing as a Hardware... Dialog box in 8.01 on when using an Mbox3? Is so, why is the selection option still there.
I am tired. It is 1:30 in the morning....I just want my new MBox to work.
Cannot get Setup>Hardware box to come up MBox3 - 8.04/5 Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-10-2011 01:49 AM
Can't access Hardware Setup Dialog??? Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2005 09:54 AM
Hardware setup dialog labels disappeared (6.1.1) apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-24-2003 06:08 AM
DIGI 001, no Ch 1-2 input in Hardware Setup dialog!? jcoker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-31-2003 04:53 PM
Strange problem in Hardware Setup dialog tld Pro Tools TDM Systems (Mac) 0 08-13-2000 08:07 AM
