Re: Yamaha synth>MIDI Channels>Pro Tools.......Yamaha user\'s LOOK!!
Now, here's what I figured out: For some reason my EX5 doesn't play back on consecutive channels (I'm guessing this is your issue, too). I have 2 MIDI tracks in PT-- 1 for drums and the other for Bass. When I have them setup on channels 1 and 2 (with the respective outputs set accordingly) I have exactly your prob-- Ch 1 works, 2 is silent (even though the meters move). So, I switched Ch.2 to Ch.3 (for both the input and output and, voila! Now my tracks are both working and playing the correct voices. It kind of sucks since I can only use 8 MIDI channels instead of 16 but, it's better than 1. If I figure anything else out, I'll let you know.
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Hey all just got back in town from the xmas holiday,which was fantastic!!Hope yours was too.
Now back to the topic at hand.I have finally got all 16 midi channels to transmit to each other properly!!Although i am still figuring things out,i am getting the 16 ch.'s to respond to their respective pro tools ch.'s. I'll go through my setting's in the board and also in pro tools and post them tonight [img]images/icons/smile.gif[/img] Also,cwhite have you been able to get more than just the 8 channels? being that you have 8,i'm wondering if their may be some type of stereo settings that you need to change....Just a thought.....I'll post back again tonight. |
OK i'm back with my results:
Seq play mode>Utility>Midi Basic Res Ch>omni Device No.>all KBD Trans Ch>16 File utilityID>1 >Switch Bank sel.>on Pgm chng>on CntrlChng>model Local>on Rcv bulk>protect >OTHER Midi in/out>midi thru port>8 These are my settings in the board,i had to turn OFF midi thru inside Pro Tools also.I still have some questions to direct at Yamaha tech support,they're closed until monday.But i am finaly getting all my channels into PT's. Hope this help you with your settings cwhite i realize you have an EX5?...but maybe some of this will work for you.Post your results and if i can help at all i will. |
Hey B-man,
I haven't had a chance to mess around anymore since my previous discovery-- curious to see what you came up with. Thanks.
Pro Tools and Yamaha Motif XS8 Midi Issue | DonaldM | MIDI | 3 | 07-02-2009 07:46 AM |
HELP! Yamaha Motif 8 + Pro Tools 7.0 MIDI | TheProjectPiper | MIDI | 1 | 03-18-2008 01:32 PM |
Yamaha 01V - How do you apply FX to the Adat channels? | Blake McGinnis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-30-2003 07:22 PM |
Yamaha G50 guitar synth | gargoyle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2003 09:54 AM |
yamaha Motif synth /ws | stut5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 06-10-2002 05:43 PM |
