Problems after Security Update 2008-008
So, I stupidly let Software Update do it's thing, and update the 2008-008 security update. I'm on OSX 10.4.11, running PT HD 7.3.1cs7. However, PT will now not run - it bounces once on the dock, and that's it.
I've tried all the usual fixes - prebind script, installing the 10.4.11 combo update, updating PT, and have done a clean uninstall/reinstall of PT, all to no avail. Has anyone else come across this problem, and does anyone have any possible solutions? Thanks a lot! Gethin |
Re: Problems after Security Update 2008-008
same problem here!!! S**T!
if you don't have a clone back up get one..reinstall everything then clone that good drive so this or anything like this can ever happen to you again. if you can't afford another drive...ask God...HE will provide. any more questions?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Thanks for the heads up! Security Updates are generally pretty harmless.
However, there appears to be (or have been) a problem with the update. According to several sources the update may have not completely downloaded, yet somehow still passed a checksum verification and then continued to try to install, thereby screwing your system. According to Macintouch, Apple forums, etc., the key is to re-install the combo updater after booting from the DVD. Here's another fix mentioned . . . Quote:
Yeah, it's a bit frustrating - I never install any os updates or anything big like that via the automatic updater, but thought that security updates were generally safe, won't make that mistake again!
I've ended up just making a new osx user profile, which, along with all the reinstalling, re-updating etc that I've done seems to have fixed it. Although it still won't run in the original profile which is a bit frustrating. I also tried installing the update via the apple website (ie download, and run the .pkg, although without having deleted the partial file) which didn't seem to fix things, so i'd be wary about installing the update that way as well. Protools seems to be the only thing that's broken though, so I'm not convinced that a faulty download caused my problems. |
HELP !!!
Logging in as a new user will work. However.... I have lost my registration code. I have my serial number. Any help there ?? I have done all the install and reinstalls. Doesn't seem to work.
Zack |
Hello, what we have found to work is to right click on the Actual Pro Tools HD application, and select Show Package Contents. Then open the Contents folder, and then open the MacOS folder. Then in here open the Pro Tools HD Unix file and it should work. Maybe the security update broke some binding between the Icon and the actual unix executable.
So, it's almost working now, I've got it running in the new user profile now, but it seems that every time I reboot I have to trash the preferences before I can run protools, otherwise I just get the dead dock icon. Very odd. Any ideas what might be causing this? Or am I just going to have to deal with deleting preferences every time I turn my computer on!
Last login: Thu Dec 18 10:38:11 on console /Applications/Digidesign/Pro\ Tools/Pro\ Tools\ LE.app/Contents/MacOS/Pro\ Tools\ LE; exit Welcome to Darwin! joshua-rosenthals-computer:~ joshuarosenthal$ /Applications/Digidesign/Pro\ Tools/Pro\ Tools\ LE.app/Contents/MacOS/Pro\ Tools\ LE; exit Illegal instruction logout [Process completed] IT SEEMS THERE IS AN "ILLEGAL INSTRUCTION" PREVENTING IT FROM LOADING. |
I'm swamped with other support requests at the moment, so I can't test this and find a fix personally, but I'm going to see if I can't get someone on the case. |
Intel Mac (tiger 10.4.11) security update...Problems?? | BFin | Pro Tools M-Powered (Mac) | 2 | 01-02-2010 11:55 PM |
PT 7.1.1 Security Update Bug Fix | tickles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-26-2009 07:51 AM |
Do Not Install Last Security Update!!!!!!!!!! | Gons Deejay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-23-2007 11:01 PM |
Mac OSX Security update | Earfatigue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-09-2005 11:47 AM |
Apple's security update is out, should i update? | Arvid Gunardi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-25-2003 09:00 AM |
