drop tuning guitars
i have been checking out some of the tunings some of my favorite bands use so i can go after some of their sounds when i record. most of them are tuning down 2 steps. my question is i have a gibson les paul is their any danger of warping the neck or other problems by tuning this low. i thought about tuning down for recording and tuning back to standard after i was done but seems like this would wear the strings out quickly. any suggestions or tips will be aprreciated.
Re: drop tuning guitars
Of all guitars, a Les Paul should be the ONE to drop tune. More than likely the bands are either tracking or playing with a Paul. Floating bridges are much harder to get into DROP tuning. All my guitars are floyd rose bridges and have a hell of a time dropping the tuning because each time you drop the thig, the floating bridge lowers or raises cause a intonation problem. The FIXED bridge guitars have no issues really. I do recommend using heavier gauge strings when you do though. At least 11's. If you can go 12's that is even better. The lower the note and THINNER the string the thinner it will sound. Thick HEAVY gauge strings will get you more tone overall and with a drop tuning NOT affect the meck. Hell man, te PUAL is about the thickest neck out there. NO WORRIES!
Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
My son's band plays all of their music (original) with tuning dropped 2 steps. He has a Strat with a Warmoth neck (awesome neck). I put 11's on his guitar (he was originally set up with 10's) and use 5 springs in the bridge and have it adjusted so the bridge is tight against the guitar body. When I set it up for him I needed to adjust the truss rod even with the 11's for proper action (had to adjust to provide some relief). The Les Paul should accomodate the drop tuning, but you still might have to adjust the truss rod for proper action depending on what string gauge you normally use and your original string height. Two steps is a lot, but common.
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
Also make sure you re-adjust the intonation every time you change the tuning.
shouldn't be a problem with a les paul, tele, strat, or prs as long as you take some care to set them up for the specific tuning. heavier strings and a good tech and your guitars will be happy. you may also want to look into a baritone guitar that'll give you a couple extra frets and handle b-to-b tunings specifically. does wonders for c and drop b stuff.
-s dragonflyeast.com (studio) myspace.com/scottspelbring (production) |
tuning | haydenluis | The Drum Room | 1 | 01-29-2010 04:10 PM |
pulldown and drop/non drop problems | ilinx | Post - Surround - Video | 2 | 05-16-2008 09:46 AM |
Lining up Drop Frame to Non Drop | Roger Stauss | Post - Surround - Video | 4 | 10-10-2007 06:36 AM |
Tuning | will the moor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-22-2005 01:55 PM |
002 tuning on and off by itself | MookHustle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-15-2005 12:10 PM |
