Pro Tools Commit - Not routing through master fader
Hey Toolies!
So I upgraded (subscribed) to PT v12.6.0 - specifically and only for the "Commit" function so I can bounce out my stems simultaneously (as opposed to ol' solo each track and then bouncing stems individually). My issue (or query) is that when I commit an audio track so it renders and then imports the wet (.cm) track with effects printed. It doesn't seem to have routed the original tracks level through the master fader before the .cm track is committed and re-imported. You would think by committing a track, you're committing it to the level of the bus that it's being routed to?? (in this case being the Analoge 1-2 output of kick > Analogue 1-2 input of master fader) Am I wrong? So for example, I have a audio track (kick drum) with EQ inserted. The gain meter on the kick track is sitting at -1.7db when hitting. And I can see that on my master fader, the gain of the kick is sitting around -12.5db, this is because I have my master fader pulled down to around -22db (giving me headroom for when I give it master engineer) But when I commit the track and it is reimported, the effects are printed, but the kicks gain is still sitting at -12.5db - Not at -22db (master fader level) which is what it would have been rendered to if I had just soloed the kick and bounced that track individually (the old way). This is an issue because I mix my projects referencing the master meter and the gain stage that it arrives there with. If I just commit all my tracks so then I can then Shift+K export, this isn't going to reflect my mix because the gain is not post-master Surely I'm doing something wrong because if so, then this can't be effectively used to "bounce multiple tracks simultaneously". The same old solution must still be to just solo each track one at a time and bounce individually I've attached a picture of the commit settings that I've used in this example (I don't use automation so I don't check those flags, but I have also tried with them flagged and it doesn't seem to achieve what I'm looking for. Thank you heaps in advance for the time & support, and please remember I'm not a PT guru. Just a bloke looking for some answers.. Cheers |
Re: Pro Tools Commit - Not routing through master fader
HI samv !
I maybe wrong ( have to read more about it ) but as far i understand the commit track feature are pre Master Fader . I don't use this feature very much to be honest . :-/
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
It's working as intended. Committing a track is just that, committing that track with its processing. If it worked the way you want, then you'd be double processing all your track because they'd go through the master fader's processing twice.
The goal of the feature is to render out individual tracks (or busses) that you are "finished with" and don't intend to tweak anymore. Either to future proof them or to free up CPU cycles. |
Indeed^^^ If you want/need the master to be "involved", then you should use Bounce To Disk instead of Commit
Bounce To Disk/Offline/Import After Bounce.
Pro Tools Mackie Control. master fader?? | Kerochan | Pro Tools 12 | 2 | 07-05-2016 12:37 AM |
Master fader/fadeouts Pro Tools 8 | wordupdowndog | Pro Tools M-Powered (Win) | 3 | 01-10-2012 01:39 PM |
trouble routing to master fader | radioinactive | Pro Tools TDM Systems (Mac) | 15 | 11-02-2010 11:35 AM |
Routing around the Master Fader | 2hip2b4real | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-05-2008 11:25 AM |
Routing output of master fader | MPB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-14-2003 12:44 PM |
