Old 02-28-2022, 08:11 AM
moes moes is offline
Default Waves pluggins not showing up!
Used to record on my crappy laptop but just bought a new strong laptop so i can record music with less wories
I just got the
LENOVO Legion 5 Pro 16-Ryzen 7 32GB 1TB RTX3070
Just downloaded some waves pluggins but there not showing up.
i tried this:
Windows:
Quit Pro Tools.
Press [Win key]+R, type %appdata% and hit Enter. In the Roaming folder that shows, go to Avid > Pro Tools.
Locate the InstalledAAXPlugins file and drag it to your desktop
Launch Pro Tools. If prompted to Locate the Waves plugins folder, direct to C:\Program Files (x86)\Waves\Plug-Ins V13 (or whichever version is installed on your device).
If everything then works properly, you can delete InstalledAAXPLugins from your desktop.
But that doesnt work because when i open up pro tools it automaticly brings back the InstalledAAXPlugins file.
Old 02-28-2022, 10:23 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Waves pluggins not showing up!
First check the version of Waves you downloaded is compatible with your OS version and Pro Tools version. Second, you have to install - and authorize - Waves using Wave Central.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-28-2022, 11:35 AM
Pro tools 12 and waves 11
Old 02-28-2022, 12:36 PM
Is that good?
Old 02-28-2022, 01:12 PM
help me out guys
Old 02-28-2022, 01:52 PM
EGS's Avatar
EGS EGS is offline
... Second, you have to install - and authorize - Waves using Wave Central.
yep
Click for audio/video demo
Click for resume
Old 03-01-2022, 12:56 AM
nope
Old 03-01-2022, 11:09 AM
DigiTechSupt's Avatar
Question Re: Waves pluggins not showing up!
Hello moes,
  1. Is this Pro Tools First (which requires plug-ins to be purchased through our Marketplace) or Pro Tools?
  2. What is the actual version # installed? (Check file info or splash screen.)
Thank you,
DTS
Avid Audio Tech Support
Support FAQ
Old 03-01-2022, 01:25 PM
Indeed, Pro Tools First cannot use plugins unless they came from the Avid store. Next, there is this bit:
"If prompted to Locate the Waves plugins folder, direct to C:\Program Files (x86)\Waves\Plug-Ins V13 (or whichever version is installed on your device)."
This is the location for the older 32 bit plugins and NOT where any current 64 bit plugin belongs. That should be here:
C:/Program Files/Common Files/Avid/Audio/Plugins
If they were properly installed, scroll way down and you should find a folder named "WaveShell...."
Waves Tune Not Showing Up Altrana AAX Plug-ins 5 01-26-2022 06:49 AM
WAVES WNS not showing up in PT 11 David Sandwisch AAX Plug-ins 5 11-29-2013 01:19 AM
No waves plugins showing??? Raoul23 Windows 5 05-16-2011 02:15 PM
Waves Plugin Not Showing Up Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-13-2007 12:53 PM
latency problem caused by waves pluggins? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-29-2002 02:33 PM
