Old 11-03-2021, 12:43 AM
Stenolle Stenolle is offline
Default Plugin selection menu changes (cannot search for plugins)
Been having this issue and since it's hard for me to describe, I wasn't able to search for it either from earlier threads.
The plugin menu randomly changes it's behaviour, when it's "dark" (picture attached), it works just fine, but when it's "light", it doesn't allow to search for plugins or IO routings.
I'm actually pretty sure it's more to do with Mac OS than Pro Tools, but for the life of me cannot figure out how to solve it.
Broad specs:
PT 2021.7
Mac OS Big Sur
Mac Mini 2018
Old 11-03-2021, 02:17 AM
ToxicGandhi ToxicGandhi is offline
Default Re: Plugin selection menu changes (cannot search for plugins)
Hi!
I just want to report the same issue, I haven't figured out the cause either.
PT 2021.10 (but it has been happening on my previous install as well, which I believe was 2021.3.1)
MacOS 10.14.6
MacBook Pro 15" mid-2014
Old 11-03-2021, 03:04 AM
Going to disagree on that, I would much more expect this is a Pro Tools bug.
Have folks who see this customized any of the UI colors or other things?
I would try trashing prefs.
In a quick test I can't reproduce it on my system running a more recent 15" MBP with 2021.10 on Big Sur.
Old 11-03-2021, 06:55 AM
TJ Allen TJ Allen is online now
Are you using Soundflow? If so, this is a well documented issue over on the Soundflow forum caused by the way Soundflow interacts with Pro Tools via Accessibility mode.
Old 11-03-2021, 07:31 AM
JingleDjango JingleDjango is offline
Keyboard Maestro also can trigger this behaviour. In particular I've noticed it when using KM to call Audiosuite plug-ins and render to the timeline.
Old 11-03-2021, 07:54 AM
peapodpost peapodpost is offline
confirming this issue here on many setups
... all using keyboard maestro & soundflow!
good to know!
Setting to make plugin selection in DAW follow channel selection? polyh3dron Avid S4/S6 16 08-23-2021 09:23 PM
Shortcut to go to help menu search field @tention Pro Tools 2020 1 09-22-2020 05:21 AM
pro tools plugin menu, and options menu blank lucidlife Pro Tools 10 4 12-07-2014 12:16 AM
Random Plugin Selection/Plugin Selection Shortcut issues thebeatless Pro Tools HDX & HD Native Systems (Mac) 10 08-05-2014 10:52 PM
rewire plugins not showing up in plugin menu stereohi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-18-2008 05:55 PM
