Master Fader question
I am voicing a script for a radio piece, and I think for some reason I have trouble modulating my voice. Even if I think the levels are set right, it tends to peak sometimes.
I don't know a lot about how the master fader tool works. But maybe it's another tool I'm looking for. I just want to compress all of the clips so they basically fall along the same volume level. What's the best way to do this? |
Re: Master Fader question
A master fader in Pro Tools basically allows you to monitor an output/pair of outputs, and to put inserts on them. By itself, it is not a processing tool.
If you find that you are getting abrupt peaks that cause clipping, try reducing the attack time on the compressor. If there are a lot of dynamics in your voice performance, I would recommend using two compressors - one with a very low ratio (e.g. 1:1.5) and threshold to gently reduce the dynamic range, and then another after it with a fast attack, high ratio and high threshold to cut down the peaks. You could also use a little level automation to smooth out general levels, but on spoken word it should be quite subtle. Hope this helps. |
Record with lower gain and use a compressor at mix to level your voice with makeup gain to bring it up as loud as you want in the final print.
You also might be too close to the mic when tracking.
Increase the space between you and the mic, and you'll be surprised how much smoother, and less spikey it can be. |
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
master fader question | Souf Centrol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 02-15-2008 11:03 PM |
Master Fader Question | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-12-2006 07:07 AM |
Master Fader Question | HR123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-23-2003 01:15 AM |
Master fader question??? | Tom Harmon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-09-2002 08:10 AM |
