  #21
Old 06-10-2021, 04:20 PM
digiot digiot is offline
Default Re: Question regarding both HDX and Carbon
Originally Posted by LFO View Post
Well, for myself I prefer to to everything from beginning to end in Protools (although I also use Ableton Live but for things impossible in Protools) and you're right VIs are not really easy inside ProTools, so I use VE Pro mostly using a second computer to host VIs. To me it's a very convenient way.
Yup, I have 4 slave computers running VEPro to work on orchestral mock ups. I hardly use VI's inside Protools. For lighter VI usage I just run VEPro on the same machine as Protools.
  #22
Old 06-10-2021, 04:24 PM
Originally Posted by nst7 View Post
Just curious, you guys using VE Pro, especially on a second computer, are there advantages to that vs. hosting your instruments in another DAW, such as Logic?
If you are at al serious about VI's you should at least look up some of the videos on the VSL website. I have been using them since version 1.
You could also download a demo and try it out.
  #23
Old 06-11-2021, 03:27 AM
LFO LFO is offline
To me it’s simpler with VE pro, routing very flexible with just an Ethernet connexion and Protools store all the VE configuration so all you have to do when working on a session in progress is to open it.
  #24
Old 06-11-2021, 08:33 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Just confirming Carbon's latency for output alone is ~6ms at 32 buffer 48kHz. About 7ms output with 64 buffer. That's what you'd be up against for VIs.
  #25
Old 06-11-2021, 11:02 AM
K Roche's Avatar
K Roche K Roche is offline
While it could be as I have not measured. BUT I am curious "confirming" according to what data or who exactly ? And any idea as to how it was actually measured ? I would be interested in confirming that on my system, thanks K....
System :
Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #26
Old 05-26-2022, 07:27 AM
TNM TNM is offline
Originally Posted by digiot View Post
Yup all of that makes sense except for the fact that I don't understand people using Protools for composition with massive VI loads!? There are much better alternatives to Protools for that
I looooooooove pro tools for composition.
YMMV!
This coming from a hardcore logic user of 20 years prior my switch. Yep, 20 whole years, from 1997.
Now with the new drum sequencer which I have yet to install, drum programming is going to be much easier too.
-Whenever I launch Pro Tools, I get wet.(™)
-Lenovo Legion 7i, Intel 11800H OC @4.8ghz, 64GB ram, Nvidia 3070 MaxP, Win 10, TBolt 4/Apollo 8/ProTools 2021/Nuendo 11
-Razer 15 Advanced, Intel 11800H, 32GB ram, Nvidia 3070 MaxQ, Win 11, TBolt 4/Apollo Twin/ProTools 2021/Nuendo 11
  #27
Old 05-26-2022, 07:28 AM
TNM TNM is offline
Native is subject to buffer, protocol, converter delay, and driver. VIs are only affected by output latency, true. At 256 buffer that's about 9ms with Carbon and about 6ms with HDX. An Apollo WITHOUT LLM enabled (monitoring straight through PT and not using Console) is 6ms output latency at 256. Quantum is 5ms.
I agree Carbon and HDX aren't terrible for VIs, but if that's the focus they should be avoided, since native systems will provide superior latency for less investment.
However, HDX minimum buffer at 48kHz is 64 still, IIRC, while native interfaces are 32.
Taking all the above into consideration, the *absolute minimum* output latency is 4ms for Carbon, 2.5ms for HDX, 1.5ms for Apollo, and sub 1ms for Quantum.
Keep in mind this whole thread is about *native* plugins for input monitor paths with Carbon/HDX vs Native interfaces. Native is built for this and performs better. If we're talking audio input monitoring then DSP would come into play and Carbon (and, to a lesser extent HDX) would prove far superior to native RTL.
great to know.
when you say 4MS for carbon, I presume that's at 64 buffer...
but what sample rate? If that's 96K, that's very high.. if 48k, that's great. I can live with that for VI's.
Edit, just saw your more recent posts... I can't live with 7ms output for VI.. so that's scratched. I am always on the look for an all in one and never seem to find it. It just means the native driver side of carbon needs tons of work, IMO.
I think I am just going to get an intel second hand imac pro which will work with everything and continue to use my UADs in bootcamp with PT, as imac pro's work brilliantly with bootcamp and are quiet as (10 core model). I see one going for less than half what I originally paid for my 8 core lol..
Windows hasn't worked out with the Apollos as TBolt 4 is not compatible with TB3 adapters, so I have been using older USB devices and it's been a pain.
or I'll sell all my UAD gear and just get the new X6 or X8. Maybe that. They work in TB4 ports.
The lowest output latency on Apollo thunderbolt gets very low, even at 44K.
  #28
Old 05-26-2022, 08:26 AM
Carl Lie Carl Lie is offline
One more thing about VI's. When running HDx in it's normal mode, VI latency is low. I can set an output buffer to 512 (44.1 SR) while using HDx and still record midi drum tracks with no noticeable delay.
I have HDx and love it. Having the power to add tracks later in the game at low latency is awesome.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Question on New Carbon License... tomhartman Pro Tools | Carbon 4 05-06-2021 12:36 PM
Question re Carbon and Using Two DAWS... tomhartman Pro Tools | Carbon 2 05-04-2021 11:03 AM
Carbon DSP Plug-Ins Question Tweakhead Pro Tools | Carbon 17 12-18-2020 12:58 PM
Carbon Copy Cloner question WildHoney Pro Tools TDM Systems (Mac) 3 01-05-2009 09:49 AM
