Automate in Latch Mode during Loop
Hi guys,
when looping a section and writing automation in it using latch mode, it stops writing once it reaches the end of the loop as if playback had stopped. Is it possible to turn that off? |
Re: Automate in Latch Mode during Loop
Not in Latch Mode, but in Write Mode with Pref "After Write Pass, Switch To Options - No Change",
or with HD : Preview Automation. (At least in PT 11.)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thanks for answering!
I knew about the Write mode, but the problem with it is that it overwrites every parameter, even the ones that hadn't been changed. Imagine you have a low pass moving up in a clip and you also want to have a constant eq setting in addition to that. If you hit Write mode and adjust the eq setting, it will also overwrite the low pass movement. |
PT HD with Preview Automation is THE solution (ähem : ebay, search worldwide).
Workaround, in your example : One EQ with the moving Low Pass, but set to "Automation Safe". Another EQ for the constant setting. Automation Window : everything than "Plug In" deselected. (And any other plugin insert except the constant-setting-EQ set to Automation Safe.) Or : do all static automation first with write, than with other modes the dynamic ones.
If for example your clip already has the low pass move, and if you have HD, then make a selection around the clip and click on PREVIEW mode. You might set it to loop play at this point.
You can make a change to your EQ to set your constant, then you can click on the "manual write to selected" in the automation window. This will add your new EQ setting without changing your low pass move, as long as you didn't touch any of the low pass parameters. Look up (in quotes) "punch preview" in the reference guide PDF to find different ways to do this. Give it a shot! G.
Garrard Whatley Seismic Post Audio Post Audio for Film and Television System/Hardware Info IMDb credits |
Yeah, I also thought about inserting a second eq only for the moving low pass.
gwahtley, I know about the preview mode in HD, and I would die for it, but I don't have Pro Tools HD. Quote:
Understood. Can't always see all the system details in Tapatalk (if it happens to be in your signature, it didn't show up here). good luck!!
Touch/Latch mode 003 | bassmonsta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2012 08:23 AM |
Latch Mode not working/sporadic | AudioMaster | Pro Tools TDM Systems (Mac) | 8 | 05-26-2009 05:50 PM |
The "Gravity Effect" in Latch Mode. | wolfdavis | ProControl, Control|24, Command|8 | 6 | 09-19-2006 02:56 PM |
'Latch' Talkback Mode | steve m soundworks | ICON & C|24 | 2 | 03-28-2005 05:43 AM |
Switching to Latch mode after AutoWrite... | GVDB | Pro Tools TDM Systems (Mac) | 1 | 08-26-2004 01:28 PM |
