Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-21-2014, 11:54 AM
iamthebeautifulmess iamthebeautifulmess is offline
Default Can't Mic to connect properly to mbox mini via Presonus Pre Amp
I have Pro Tools 8 LE both Win/Mac, Logic Pro 9 as well. a Presonus Pre-amp running into Mbox Mini. I had it working, but something isn't working now. I didn't do the initial setup which is a part of this problem and I didn't know how to. At this point I can hear myself through my monitors, but I get no feedback during playback. No level movement at all. The gauge in the middle of my Preamp (VU) the needle doesn't move at all.
Please help.
I believe I have things connected incorrectly most likely wiring and connection wise, but again I'm definitely a novice.
Old 04-22-2014, 10:11 AM
Default Re: Can't Mic to connect properly to mbox mini via Presonus Pre Amp
The Presonus preamp should go into the Mbox input #2(quarter inch) and then you would select input 2 for the track(depending on how you have your IO named). If input 2 on the Mbox has a GAIN knob, it should be turned down all the way.
Mbox 2 mini does not work properly on Win7 and PT8.0.5 jalber 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-18-2012 08:14 AM
Mbox Mini not working properly, help please. merlinhimself 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-13-2012 07:45 PM
mbox 2 mini don't work properly in windows 7 64bit funkman733 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2011 02:05 PM
Connect MPC 5000 to mbox mini sytrusze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-09-2010 10:59 AM
Mbox 2 Mini won't connect to my MacBook! ddj1991 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2008 07:00 AM
