Is there any way to make bomb factory work with XP
Will any 98/Me pluggins work with XP? Is there a tweak or anything that can be done?
Re: Is there any way to make bomb factory work with XP
Not supported or recommended by BF, and only works for about 1/2 the people who try... right click on the PT.EXE file, and choose the compatability tab, and select "run this program in Windows 2000 (or NT4 SP5) compatability mode".
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
is there any explaination why it only works for half of XP users?
Boo !!!!
There's a great mystery that lies behind the doors of Digidesign Castle, no one knows exactly what's happening... There are certain things that we'll never have explanations in this world. Like the Bermuda Tringle, the caramel in the caramilk,Spdif mirroing, why some functions works with some machines and so on... Are you scared !!!! Boo!!! |
maybe problems with the reg key?!?!?!
Ok I have figuered out a way to get these plugins working without any problem. As you guys know, I couldnt get mine to work either. I tried to do the compatability mode for the main PT exe file but it did not work. But this will!!!
Go to your pro tools folder and make a shortcut of the protools main exe file and put it on your desktop. then right click and do the comptability mode trick to the SHORTCUT. Open the shortcut to protools and everything should work. Make shure the MAIN PRO TOOLS FILE is not in a compatability mode and only the shortcut is. Try it out and tell me if it works. HAVE FUN! |
Impressive, how did you come up with this? This kid deserves a bottle of Captain M.
[img]images/icons/grin.gif[/img]
Digi002R PT6.7 SP1 K8Vdx AMD643200 GeilPC32001G HitSATA80GB(sys) 2xSATA160GB GlyphXFW NEC2500DVDRW Sapph9600ProU SonyP234LCD AntecSonata Zalman7000Al |
I can't understand... Is this a joke ? When I try the compatibility trick on the shortcut, I always get the same result on the .exe file...
Still doesn't work for me ! ...Someone else ?
... et voila ! |
worked for me
it works. Thanks
Bomb Factory Pultec Bundle MEQ2 wont work in PT 7 | K Roche | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-03-2006 07:03 PM |
Bomb Factory Plugins won't work on MIX System. | Balanced Jack | Pro Tools TDM Systems (Mac) | 1 | 11-29-2004 11:51 AM |
Why don't my Bomb Factory demos work? | Patheticus | Pro Tools TDM Systems (Mac) | 1 | 09-16-2004 09:55 PM |
just downloaded - bomb factory doesn't work | TryThisBacon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-17-2004 10:23 PM |
Bomb Factory Fairchild 670 - Bypass doesn't work. | dcarlson247 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-17-2004 05:20 PM |
