Old 11-01-2024, 12:32 AM
abt abt is offline
Default New build specs - Your input please!
I'm about to embark on a long overdue new build. Can anyone see any issues with this?
I've done my best to maximize what I can afford (I can't really afford it) and hopefully they are compatible parts.
- Intel Core i9 14900K 24 Core LGA 1700 CPU Processor
- Gigabyte B760 Aorus Elite AX LGA 1700 ATX Motherboard
- Corsair Vengeance 64GB (2x32GB) C40 5200MHz DDR5 DRAM
- Samsung 980 1TB PCIe Gen3 M.2 2280 NVMe SSD
- Corsair iCUE 4000X RGB TG Mid Tower ATX Case - Black
- Corsair H100 RGB 240mm AIO Liquid CPU Cooler
- Corsair 850W RM850e 80+ Gold Power Supply
I did almost no research on the power supply or cooler because I'd had enough by then!
I'll be keeping my current SSDs as they are okay.
I'm hoping my existing video card will be okay - NVIDIA GeForce GTX 1070 Ti
Any help, feedback, ideas would be much appreciated!
Old 11-01-2024, 06:33 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: New build specs - Your input please!
I didn't check the compatibility of the parts, but that looks like a solid build you put together.
As for the power supply, I think you will be fine. The processor will run less than 300 watts under load, so that leaves you enough room for the other peripherals.
Your video card should be fine as well. PT isn't really heavy on graphics and that card should be okay. I'm assuming you are using whatever monitors you had before and aren't looking for higher resolutions.
If you haven't done so already, you should be able to find memory compatibility on the Gigabyte site.
Will
System Details
Old 11-01-2024, 08:45 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Looks pretty good to me and quite similar to one I just had built. Once you have it, do a clean install of all your programs and plugins. It takes longer, but sure is worth it!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Win-11/PT 2024.10/i9-14900K/Gigabye Z790MB/64GB RAM DDR5
Old 11-02-2024, 12:48 PM
I didn't see a graphics card on your parts list? As to saving money, you could drop to 32GB of RAM and a 500GB NVMe drive(as long as you keep sample libraries on their own drive). I've been running 500GB system drives for over 10 years, and 32GB is plenty of RAM if you aren't going to be running tons of instrument plugins
Old 11-02-2024, 04:52 PM
abt abt is offline
@junkgear, @DonaldM, @albee1952 - Thanks very much for the input, I have pulled the trigger. I needed a bit of a push and your feedback help a lot!
Old 11-03-2024, 10:29 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by abt View Post
... i9 14900K ... 5200MHz DDR5 ... I'm hoping my existing video card will be okay ...
With that CPU/RAM, you can skip the GPU and use iGPU only, especially if you monitor at 1080P. Also, Pro Tools is NOT overly demanding of graphics, like video renders or gaming. The iGPU can even run multiple monitors. The last couple generations of iGPUs have gotten big upgrades.
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001
Click for audio/video demo
Click for resume
Old 11-03-2024, 01:40 PM
tope d's Avatar
tope d tope d is offline
Best to follow what's listed in https://avidtech.my.salesforce-sites...m-Requirements
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 11-03-2024, 02:25 PM
Just to reemphasize, including to others building systems, (and I did not look at the list so you may be OK already), but try to use the exact make/model DIMMs qualified by the motherboard vendor. Don't assume similar spec DIMMs will work, and don't mix and match different DIMMs even of the same specs. Follow the Motherboard vendor qualification specs exactly.
It's amazing modern DRAMs work at all, there is so much going on under the covers, and so many problems can end up being related to DRAM. DRAM passing POST or other tests is not really that good a guarantee the memory is OK. The work the mother board vendors do here is pretty impressive, try to leverage that.
Old 11-04-2024, 07:09 PM
abt abt is offline
Thanks, yes, I will put the onboard GPU through it's paces before I decide if I need to use the old one.
Originally Posted by tope d View Post
Thanks. Yes, I've checked here and can't see anything that much that looks like a problem.
Thanks. Yes, I did check that they are compatible so hopefully everything will be good!
Old 11-05-2024, 06:30 AM
EGS's Avatar
EGS EGS is offline
Thanks, yes, I will put the onboard GPU through it's paces before I decide if I need to use the old one…
Cool. Let us know how iGPU works out for you. Good luck with the build!
Click for resume
New Build Review! Based on Mano/Ame? and SPCR Fanless build Calipoop Windows 4 11-16-2011 10:38 PM
PTLE 7.4 pc build specs help. PLEASE!! dudeskin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-07-2011 12:48 PM
i7 final build specs and graphics question remis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-14-2010 04:41 AM
Please lemme know if new build specs reasonable? kirkgale Pro Tools TDM Systems (Win) 4 01-31-2009 03:20 AM
desire input on new Macbook Pro specs from duc friends drguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-03-2007 01:01 PM
