Old 03-12-2013, 08:03 AM
barbara.goddy barbara.goddy is offline
Question Pro Tools could not initialize the current playback engine
Hello,
I am using ProTools 9 (LE) and the Mbox Pro 3. The computer specifications are Mac OS X, 10.6.8. Normally I didn't have any problems with launching ProTools but yesterday I saw this message on the screen:
ProTools could not initialize the current playback engine. Please make sure that device has been configured correctly.
I already tried the fallowing two tips, but it didn't help:
[B]1. Launch Pro Tools
When the splash screen appears on the screen, hold down the "n" key on your keyboard, which will eventually open the Playback Engine dialog for Pro Tools. (WHEN I PRESS DOWN THE N KEY, NOTHING HAPPENS! WHEN I CHOOSE THE SETUP MENU, THE LETTERS ARE GREY, SO THAT I CAN NOT CHOOSE THE PLAYBACK ENGINE.)
Mac Only
If the solution above fails, you can try deleting the "com.apple.audio.AggregateDevices.plist" preference on Mac OS X. You can find this preference file in the following location:
Macintosh HD > Library > Preferences I DO NOT HAVE THAT FILE IN MY PREFERENCES!
Thank You very much for the help!
Regards,
Barbara
Old 03-12-2013, 08:11 AM
Default ProTools could not initialize the current playback engine
Firstly there is no such thing as Pro Tools 9 LE. It's just Pro Tools 9.
What exact version of Pro Tools 9 are you using? Are you trying to use an aggregate IO device? (Exactly what devices aggregated together?).
Power off the Mac and Mbox Pro. Power up the Mac and once OS X is running power on the Mbox Pro. Launch Pro Tools by double clicking on the Pro Tools icon and keep holding down the single "n" key until the payback engine dialog panel appears. If that really never appears you have more serious problems, if it does appear do you see the "Mbox Pro" option? If you select that what happens?
Have you changed anything or updated any software recently?
Nect steps would be to uninstall and reinstall the Mbox Pro driver with the latest versions that support your OS X version. Do this with the Mbox disconnected and run the uninstaller that comes with the driver download, reboot then run the driver installer.
Old 03-12-2013, 08:30 AM
Default Re: ProTools could not initialize the current playback engine
For the Pro Tools 9 version, is it the Crossgrade from ProTools LE?? Where can I find the name of the version for the ProTools 9?
I tried with the N key and it works! I didn't understand properly before that I have to hold it down while launching (I tried AFTER I saw the message with the problem)
I used Skype yesterday evening. Is it possible that it disturbed somehow the settings for the ProTools....? I didn't update anything before it happened.
Thanks again!
Barbara
Barbara Goddy
Old 03-12-2013, 08:36 AM
Ah I found! The version is 9.0.6.
Bye!
Barbara Goddy
Old 03-12-2013, 09:10 AM
Default Pro Tools could not initialize the current playback engine
It is unlikely Skype , more likely just random corruption/confusion where Pro Tools was trying to open a different interface. 9.0.6 is where you want to be.
Pro Tools could not initialize the current playback device (on 10.2.0) Cosme macOS 1 07-18-2012 07:45 PM
Pro Tools could not initialize the current playback device mkpascucci macOS 4 05-01-2012 05:00 PM
Can't initialize current playback engine PT 9.03 LE mzkguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2011 07:31 PM
Pro Tools could not initialize current playback engine. mclilmack Pro Tools 9 1 08-28-2011 02:49 PM
Pro Tools could not initialize the current playback device johnwesleybarker macOS 2 01-14-2011 06:52 PM
