Old 04-05-2012, 04:08 PM
crizdee's Avatar
crizdee crizdee is offline
Unhappy Import session data crashing every time.
Been trying to import session! got a whole albums worth of sessions to import in to my mixing template and it keeps crashing every time.
I can load these sessions fine, i have also tried loading the sessions and saving them using save copy in and importing from the copy etc, but nothing works it crashes every attempt.
These sessions originated in LE, but like i said i can load the sessions fine, just can't import session data from them. after saving using save copy in, i thought it might work
got 12 sessions to get ready before tomorrow
Can't consolidate the tracks either as there are lots of muted parts they want to keep in the session!
crash log and dlog if Avid want to investigate...
http://www.sendspace.com/pro/dl/kw61qu
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-06-2012, 07:46 AM
haowai haowai is offline
Default Re: Import session data crashing every time.
maybe try export your session to OMF
Old 04-06-2012, 09:30 AM
Meads Meads is offline
Try "save copy in" into a previous version session-file.
If that doesn't help, try importing track by track to see, if it's a general problem, or maybe just concering one or two tracks that won't import.
Once you got this sorted out, one could try further from this point.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 04-06-2012, 10:05 AM
WernerF WernerF is offline
You could also just load the sessions and then import the session data that you need from your mix template.
Old 04-06-2012, 10:11 AM
Sometimes the easiest solutions are the hardest to think of. Nice one.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 08:53 AM
Protools 10.3 Crashing with import session data on Mountain Lion electroteque macOS 11 12-01-2012 02:51 PM
Import Session Data Crashing Siegfried Meier Pro Tools TDM Systems (Mac) 2 12-22-2009 12:52 PM
Feature Request: Import Session Data "time range" JKD99 Post - Surround - Video 5 05-11-2007 10:25 AM
Import session data MIDI track out of time propower Pro Tools TDM Systems (Mac) 1 03-01-2006 01:35 PM
