Old 08-02-2001, 08:26 AM
Barnaby Bristol Barnaby Bristol is offline
Default Machine Control PT5.1.1
Even with the newest MC of 5.1.1 I am still getting the aforementioned problems with DVW-500s not being able to find an in point. The machine cues and than starts slowly scrubing backwards.
In addition a new bug has appeared. If I've used the "generic" 9-pin serial node to control my VMod (which is automatically selected), then turn MC off to change to another machine, and than enable 9-Pin serial for that machine, the node remains stuck on generic and behaves in that profile. However, when I then click on the node selector to shows the list of machines, it jumps to the correct machine. And whole time the 9-Pin Remote dialog box (which is unchecked) does show the correct Machine ID. Twitchy. Anyone else?
Old 08-02-2001, 09:52 AM
rodney morris rodney morris is offline
Default Re: Machine Control PT5.1.1
I've had problems with the DVW-500 as well concerning in points. When I try to lay back to tape the in point always changes from wherever it was to the beginning of the session without me telling it anything. My preroll (set to 5 secs) goes beyond the session start time (session start is generally 2 secs before first frame of audio) but this has never been a problem in the past. Also in the past when you enabled MC and selected node, the machine would be recognized automatically. Now, when you select node you get a pop up list of machines of which there are two selections for DVW-500 : OxB000 and OxB010. What are these designations referring to? Neither one seems to work seamlessly although OxB000 seems to work better in our situation. Any thoughts or ideas?
PT 24 Mix Plus 5.1.1
(Old) Mac G4 733, 512 MB RAM
Machine Control 1.0.1
More info available upon request
BTW - I am going to check to see if there is a newer version of Machine Control as soon as I finish posting this.
Machine control lode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2004 09:59 AM
Pro control & Machine control software samcu ProControl, Control|24, Command|8 0 03-08-2004 05:24 AM
Machine Control and 6.0 Gio Mix Pro Tools TDM Systems (Mac) 1 03-12-2003 09:30 AM
MIDI Machine Control out of control zenbarai Post - Surround - Video 3 04-19-2002 08:08 AM
PT5.1 and machine control kuen Pro Tools TDM Systems (Mac) 15 05-09-2001 09:01 AM
