Old 11-23-2005, 01:52 PM
mahler007 mahler007 is offline
Default \"Stop\" or \"Play\" puts edit window in foreground
Sorry- I'm sure this is probably an easy one, but whenever I press "stop" or "play" on the transport, the edit window replaces the mixer in the foreground... This is mildly annoying, and it has never seemed to happen before. Is there anyway to change this?
Thanks!
Andrew
Old 11-23-2005, 02:32 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: \"Stop\" or \"Play\" puts edit window in foreground
you need to use the main transport window. If you use the little on top, this is really part of the edit window. So when you click it, you are clicking the edit window which brings it to the top. If you go into Windows-Show Transport, you get the main transport window which is floating so you will not change from Mix to edit.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 11:57 AM
Notation view edit while in play cause play to stop working. soybalm Pro Tools 10 1 04-18-2013 12:11 PM
Edit window not in foreground when a clip is highlighted! Herokazz Windows 0 04-14-2012 09:57 AM
When press play the stop key lite and play key blinking Sam Yin Tips & Tricks 6 12-05-2009 09:26 PM
Play and Stop Buttons both flashing - track window froze Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-08-2008 02:13 PM
