Old 01-19-2005, 03:20 AM
karaho karaho is offline
Default Machine control on 6.4.1
I´m using machine control on TDM 6.4.1 OS X with DOREMI V1m connected on gPort/ MAC G4 400Mhz/. I have troubles with sync and speed / response time/ - after connecting machine control whole system i s very slow and lazy...
Is there any solution to make it faster ??
Old 01-19-2005, 08:28 AM
Wellnitz Wellnitz is offline
Default Re: Machine control on 6.4.1
Hi karaho,
i think the best way to go with machine control is to use Keyspan´s USB to serial adapter. Works for us.
G3 stealthport was not supported by digi. the same with gport.
my 2 cent
regards
Jochen
Old 01-19-2005, 11:18 AM
niklozt niklozt is offline
I have the same issue .. OSx10.3.4, PT6.4.1cs2, V1 ... i did see the compatability docs reccommends the Keyspan USB-Serial adapter .. and no mention of gport or stealth(which i use) ... I'll have to try those as they are pretty cheap .. In the meantime however I notice that if in the Prefs>Mach Ctl> you deselect "Machine follows edit insertion/scrub" .. the system responds a lot better ... there are obvious drawbacks to this but its sometimes better than the hand moving faster than "the brain"
Old 01-19-2005, 07:48 PM
Get a Keyspan USA-28x USB-->Serial adapter for use with MachineControl. I use it with a V1, and it works like a dream, especially with Machine Follows Edit/Insertion enabled.
My system is as follows:
OS X v10.3.4
PT v6.4.1cs2
SYNC I/O
888|24
MIX Core, MIX Farm, DSP Farm
One thing you have to watch out for is a nasty bug with the Stop at Shuttle Speed Zero preference. If you are working with the V1, and all of the sudden it becomes unresponsive, check if that preference is on. Chances are it is. It's a magical bug where Stop at Shuttle Speed Zero turns on without the user turning it on.
Good luck!
Old 01-21-2005, 10:13 AM
so you think that gPort is fine to use ?? but I need Machine follows edit insertion/scrub function... maybe will buy the keyspan..
thanks
Old 01-21-2005, 10:23 AM
This maybe fix my problem - are you running on G4 400Mhz ??
Old 01-21-2005, 03:49 PM
The Keyspan will fix your problem.
I'm using 933MHz and Dual 1.25GHz machines.
Machine control lode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-21-2004 09:59 AM
Pro control & Machine control software samcu ProControl, Control|24, Command|8 0 03-08-2004 05:24 AM
Machine Control and 6.0 Gio Mix Pro Tools TDM Systems (Mac) 1 03-12-2003 09:30 AM
MIDI Machine Control out of control zenbarai Post - Surround - Video 3 04-19-2002 08:08 AM
PT5.1 and machine control kuen Pro Tools TDM Systems (Mac) 15 05-09-2001 09:01 AM
