Old 11-28-2002, 03:35 AM
remains remains is offline
Default how to change sample rate??
I recorded some tracks from ADAT to PTle via optical cable and it seems that ADAT is playing at 48k.
When I'm playing back those same track in PT they seem to be slower cause internal sample rate is set up at 44.1k
Now,I already transfered all 13 songs from ADAT to PT - can I just change internal sample rate to 48k and everything's gonna be OK?
Thanks!!!!!
Old 11-28-2002, 08:49 AM
minimoog minimoog is offline
Default Re: how to change sample rate??
ok - the easiest way to do this is to create a new session for each song. be sure to do this in the same folder as the original session file so you don't have to deal with the potential confusion of having multiple copies of the same audio files.
so, to begin:
create a new session, select 48k as the sample rate and call it "song x 48" or something so that you can readily differentiate it from the 44.1k session.
in the new session, click on the File Menu.
select Import Tracks.
locate the 44.1k session, highlight it and click Open.
under Sample Rate Conversion Options, deselect Apply SRC.
under Audio Media Options, select Refer to source media (where possible).
under Source Tracks, select all the tracks you need to import.
if necessary, check the Import Tempo/Meter Map box - this will import the tempo grid from the source session.
click ok.
the tracks will be imported into the 48k session without any sample rate conversion and will now play at the correct pitch.
Old 11-28-2002, 10:03 AM
Hey,this works great!!!!!!!!!!
Thanks a million rate!!!!
Old 11-28-2002, 10:04 AM
[img]images/icons/wink.gif[/img] [img]images/icons/wink.gif[/img] [img]images/icons/wink.gif[/img] [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
Old 11-28-2002, 05:38 PM
glad to be of help [img]images/icons/cool.gif[/img]
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 12:20 PM
Can't change sample rate Gabriel_S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-20-2012 12:43 PM
Can't Change Sample Rate jasonschwartz Pro Tools M-Powered (Win) 1 01-12-2007 12:13 AM
change sample rate of 96 i/o ronfinch Pro Tools TDM Systems (Mac) 0 06-15-2006 04:19 AM
Change Sample Rate in HD? Steven Sena Tips & Tricks 2 08-10-2002 07:33 PM
