How do I see posts prior to August 18th?
There used to be a button to chose how many days back, you want to see posts, now I can only go back as far as August 18th, so how do I see posts prior to August 18th?
Thanks, Sinisa |
Re: How do I see posts prior to August 18th?
Either globally in your preferences, or in each in each individual forum, you can change how many posts you want to access.
For instance, after you have read this post: Click on the forum link in the upper left: Pro Tools TDM for Mac OS Then go to the bottom left where you will see: Extra Information Show From the pull-down menu, choose the date range you want to be displayed, then click Change. If you want to navigate to an earlier date range, you would then click on the area at the bottom of the forum post that says Pages: Click on the link for the last number before the "next" link: >> Then you will see more pages, and you can continue navigating that way. One way to "jump" to an earlier date would be to type in a guess in the url. In the TDM Mac forum, Show from all dates, page 1 url would be this: http://duc.digidesign.com/postlist.p...sed&sb=5&o=all Changing the "page=" number from 0 to 100 would jump you page 100, which would be March 2003 if you have your number of posts to show per page set to 25 in your My Home preferences: http://duc.digidesign.com/postlist.p...sed&sb=5&o=all In the My Home section, you can choose your own default view for all forums. Go to My Home > Main Configuration > Display preferences Click on Edit, then choose your preference from the drop-down menu under Default aged threads to be displayed:
Administrator Avid Pro Audio Community |
I just registered my PT9 on August 4th.... | Von_Dingle | Pro Tools 10 | 3 | 10-31-2011 12:47 AM |
stability over prior to PT9 | basslik | Pro Tools 9 | 17 | 04-09-2011 09:00 AM |
!! August 1st is the Big Day !! | Reitzas | General Discussion | 0 | 07-25-2010 07:28 PM |
It's already August and nothing is out :( | Rock_Artist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-15-2002 11:48 PM |
Munich in August | CPettigrew | General Discussion | 0 | 07-28-1999 07:54 AM |
