Midi issue
I open an instrument track. I select a plugin that has loops. I click record. I bus it to an audio track that will record the plugin's loop. When I start recording, it's way out of sync but when I play the recorded audio, it's perfect. The same thing will occur if I pencil midi in. Its playback is out of sync but the audio that it bussed to is perfect. I've been a Tools user since 2004. This is a new one.
Re: Midi issue
You are not giving much of the expected info. IO buffer size? Sample rate? Actually happens for any VI right -- nothing to do with loops or any specific VI? Delay comp turned on? What are delay comp latency numbers showing? The colors? Computer info? Interface? ...
Understanding many causes of stuff like this is helped if you actually measure that latency, how many samples and ms? All you need to do that should be right in front of you. e.g. record one VI output to an audio track and play that track back again against the VI and record them together to another track or record into another DAW if needed. Are you sending via an Aux? If so you may be running into the fixed "disk" IO buffer size on the Aux, 1024 or 2048 samples depending on sample rate, not the input IO buffer size you configure in Pro Tools Setup>Playback Engine. Lots and lots of past discussion on this behavior and the split buffers in Pro Tools. Again measure the latency you are seeing in samples. |
Re: Midi issue
I remember this being a common issue when I used to print Superior Drummer to audio. What version of PT are you running? Why not use the track commit function(instead of bussing to an audio track and recording)?
Re: Midi issue
Thanks for replying. Dave. It's version 2019. Even though I've been using Tools since 2019, I'd not ever even heard of the Track Commit function. I'll find a video and check it out so I know going forward.
Re: Midi issue
Re: Midi issue
Having looked over the Commit Track function quickly, it seems to be focused on audio tracks. My issue is that MIDI is out of sync with the metronome. I can pencil in or play four quarter notes in midi. When I play them back, the Midi 1 is different than the metronome. Yet, if I bounce it to audio, it's perfectly synced.
Re: Midi issue
Track Commit works just fine on Instrument tracks(which you probably should be using anyway). The idea being that once things are printed, they sound fine, so Track Commit saves time, and if you commit in the off-line method, you don't need to hear things out of time. Maybe if you describe the complete picture of what you are doing, leading up to when you print, someone may have a better way to reach the end goal
Re: Midi issue
Turns out that it was all about turning off delay compensation.
MIDI problem - Midi Studio Issue | Microphone33 | MIDI | 4 | 02-27-2016 11:49 AM |
MIDI problem - Midi Studio Issue | Microphone33 | Virtual Instruments | 0 | 02-07-2016 02:09 PM |
midi issue- can see midi signal but cant's control Xpand2 | macroniche | Pro Tools 10 | 1 | 08-02-2012 12:16 AM |
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
Issue When running Midi and more than one Midi Track | amayhem | MIDI | 11 | 11-05-2009 06:52 PM |
