#31
Re: Can anyone do a step by step on using the optical as adat
This is what my hardware page in PTl looks like and on the TC it says optical lock in green but no signal.
Opt cableout from TC to IN on opt port 1 and tried port 2 out from Carbon but still nothing. It says N/A Please see setup picture. And same N/A if i put the spdif option on this pic. Someone has to know what I am missing!?
#32
And this is real basic, and I've seen it happen before, but are you sure you are connecting out to in and in to out? Do you see the red light coming down the cable (look at an angle not directly) with the other end connected to an output?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro S1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.6 RAM 32GB, SSD 4TB, GPU 19 core QNAP TVS-872XT 148TB TB3 |
#33
Optical cable red light in both ends. If i put the spdif on port 1 in Hardware and on the TC Drive and under that option optical it gets a contact via optical light on the TC but no signal. if i put the port 1 on adat it goes red on the tc. And lose the optical green connection optical light on the TC. Whatever we do it still says N/A on the 2 boxes to the left like the picture. Sorry for the crap quality!
#34
As a simple test, do this: -In Hardware Setup, set ADAT 1 Out port to S/PDIF -Connect optical cable from ADAT 1 Out port on Carbon to Clarity Optical In port -Create a new session at 44.1 -Create a new track with some audio on it and set the track output to ADAT 1: 1-2 -Ensure Clarity is configured to receive S/PDIF input -Play back in Pro Tools and see if Clarify receives the signal
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
#35
Good thought though
#36
I would hope RME accepts pro or consumer with the ADI-2, I mean of all companies to make a AD/DE that should do this with no problem... it's RME. And they even put "Pro" in the name of the box. I'd sure hope that is not causing a problem for Chris. That meter better handle consumer flagged streams as well as pro flagged streams. |
#37
Re: Q regarding how to connect TC Clarity M
All Adat outs are n/a and i hve defaulted in i/o 5 times see pic:
#39
Here is the i/o
And as you see on the above pix all adat out says n/a
TC Clarity X | antonis | Post - Surround - Video | 0 | 05-02-2018 09:32 AM |
TC Clarity M | priorytools | Avid Pro Mixing General Discussion | 1 | 09-08-2016 01:10 PM |
Is anyone using Clarity X? | antonis | Post - Surround - Video | 0 | 03-08-2016 06:15 AM |
Mic clarity | bannerj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2004 09:07 AM |
Clarity in mixes | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 06-20-2002 10:54 AM |
