Problems with MIDI polyphony
Hey guys,
I'm trying to use Battery 2 with Protools 6.9, but I am having problems. Battery works fine in my other software, but when using it in Protools it drops out on some of the notes that are there. I can put 16 16th notes in a bar, but they won't all play. I figured it was something to do with the Battery settings, but they are the same as what I use in Cubase. This isn't an issue of whether my system is powerful enough, because I can easily run 40 tracks with effects. Any ideas??
Music Is Life |
Re: Problems with MIDI polyphony
I've experienced this too.. I hadn't spent enoug time trouble shooting to find a fix..
one thing I did suspect might be a wierd sorta fix would be to write half the midi notes (e.g. C 1 through C 4) on one midi track, then half on another.. C 1 to C 4 was a total example, so.. it'll probably have to be.. like.. more narrow than that. unless anyone knows of a cool third party program.. I know Live 4 is rewire enabled. I wonder if there's a way to track down drums within Live, import them over to PT, then be set from there? just throwing that out there.. good luck with it, mate..
What's protools? =D |
I'm experiencing this issue as well. I just posted this at the NI Yahoo group:
I am utilizing Battery 2 as an RTAS plug-in in ProTools 6.4 LE (XP SP1a). If I program more than one hit to sound simultaneously, only one (or none) of the hits will sound. (This occurs with MIDI demo files as well.) I am not utilizing any other plug-ins, nor does the session have any other tracks. I have set maximum polyphony from 32 to 256; no change. System resources are not being taxed. Has anyone else experienced this? I have a feeling I'm missing something very stupid and basic. Thank you. I'll let you know if I receive any responses. |
Same problem here DAbsolute.
Music Is Life |
I have the same problem with Battery1 and Cubase Sx.
Now I sequence only with PT (6.9) using Battery1 (wrapped to RTAS or Rewire) I don't experience the problem. I suppose it's not a PT issue. |
Thanks. I used the wrapper and now it seems to be fine.
Music Is Life |
Polyphony | wgouldsby | macOS | 2 | 12-22-2011 05:04 PM |
7.4.2 LE AIR products drop-out (Polyphony?) | Paul PT | Tips & Tricks | 0 | 07-03-2008 05:14 AM |
MIDI Polyphony | Room24Prod | MIDI | 2 | 01-27-2005 07:27 AM |
SampleTank SE Polyphony | AllThingsMusicStudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-10-2004 11:33 PM |
Polyphony question... | Mr Peete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-01-2003 03:27 AM |
