OT - wiring a vocal booth
I'm in the process of building a vocal booth and I'm having a hard time figuring out how to run XLR and headphones cables into the booth. Ideally I'd like to have wall plates on the outside and inside of the booth that are connected on the inside of the wall. Then I could just plug in from either side. Is there a way to do this without soldering anything? I have no soldering experience. I found a "Panel Mount XLR Feed Thru Barrel Connector" that is female on both sides (made by TecNec here). It's really nothing more than a cable extender that happens to mount into a rack panel. If I could find one of these for 1/4" TRS I'd be set. Does this item exist? Or is there a better way to do this? Thanks in advance.
-James |
Re: OT - wiring a vocal booth
ahh man,
learn to solder! I'll admit I haven't touched the iron in ages, but.. just knowing how can really keep your quality on the up. if I was building a vocal booth and didn't want to grab my iron, I'd just drill a hole and run a cable straight out, but then you'll get some bleeding (very little, but still could be a problem, depending on the location of the booth). so.. you're best bet is to buy a plate and just have at it with the soldering bit. while soldering is a bit of a craft, it isn't too difficult, and there's gotta be a ton of websites around the that'll offer tips, etc.. hope this made sense, I didn't get any sleep last night =D ...any comments doc?
What's protools? =D |
Just buy a snake... I have these, they work perfectly.
http://www.procosound.com/contractors/snakes/index.htm
www.carvelstudios.com |
Also, you can order the "inside" & "outside" plates prewired from Rapco distributors. This way you can still get the same result without touching the iron. You just need to make sure that the plate will fit through your cutout. You can also choose the type / color of metal & have it engraved per your specifications.
http://www.rapco.com/catalog/default...lwork.htm&ID=7
A7V333, XP2600+ Barton Radeon 9000 DDRAM 512MB PC-2700 Crucial x2 HD 120GB HITC 7200R 8MB x2 CDRW Liteon 52x32x52 002 |
Learn to solder. IMHO it is a must skill for an enginner.
Vocal Booth? | Bart HLH | General Discussion | 5 | 03-02-2007 05:48 PM |
Vocal Booth | Mr.BossPlaya | Tips & Tricks | 4 | 07-04-2006 08:33 AM |
Vocal booth | SKI | Pro Tools TDM Systems (Mac) | 7 | 03-23-2003 12:05 AM |
windows for vocal booth | StainedClass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-20-2003 12:11 AM |
Vocal Booth | smrp | Tips & Tricks | 5 | 05-31-2000 01:06 PM |
