Can you populate playlists automatically?
Several people agree that playlists are a better/faster way to doing comping of multiple takes into a composite track with the best segments into one regio.
However, what about us new people, who have several takes (ie 20) that are in regions vox_1 to vox_20, and furthermore, its overdubbed onto the middle of a long, live session? (regions). Is there a way to get this into playlists for comping? Should I start by creating a new session with Just that one song inside it? Do playlists ensure that switching takes stay lined up to the start point region (assuming that start point is identical in each take?) If its not identical, then I am screwed? thanks to all
N/A |
Re: Can you populate playlists automatically?
Although I'm not sure if I totally understand your question...but I'll take a stab.
What you can do is use the "Duplicate" command within the Playlist menu. This will allow you to create an exact copy of the track...all regions intact and at the exact time locations. With a copy of the track(s), you can then manipulate the new playlists to your liking, without fear of altering the originals. Brent |
What he said...
elijah |
create a new track next to the one you want, and name the playlist. Select the pieces you want and copy/paste them in the new track. When you are done, select the playlist in the other track and remove the temp-track....
What's that? - That's the machine that goes "pling". Bastiaan |
Does the Duplicate trick POPULATE THE playlists from the Regions list? If so, how does the right set of regions enter the playlist?. The user guide is not clear on the interplay between regions and playlists, for solving this problem. Why Not upgrade the software to take a set of regions, optionally force a starting point, and populate named playlists for Comping? Seems like that would be common, fast solution. I would call that Automated Playlists for Comping..... thanks. KC.
N/A |
I think it's the 'populate' thing that is hanging us up. Bastiaan pretty much views it the same way I do; to expand on that, you'll have to create a new playlist and drag your regions (takes) out to the new playlist to create what you didn't do before by just recording straight onto the playlist.
I think I understand the concept, and it may be a function that TDM does (I don't know)... I do know TDM will allow you to pick a region in the regions list and automatically replace a chosen region in the playlist, something I would really like LE to do. Right now, manually placing the region is how you'll have to go- |
Automatically Return to Zero | DirtyDingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-09-2010 03:10 PM |
punching in and out automatically | jeradbay | General Discussion | 9 | 12-04-2009 09:04 AM |
Automatically create new playlists not working with midi | eyjolfurg | Pro Tools M-Powered (Win) | 2 | 05-27-2009 03:16 PM |
Populate database comment in digibase catalogs? | thetourist | Post - Surround - Video | 6 | 09-18-2006 12:49 PM |
OT: Please help populate and post to my forum | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-11-2004 07:15 AM |
