Can't select Marker - PT 2021.12.0
Hello !
I have a strange behaviour on my PT. The problem is : when i click on a marker, the playback blue arrow does not follow. I use PT since 10+ years and never had that. I tried to create a blank session, same problem. Link Timeline and Edit selection is enabled. Play Start Marker Follows Timeline selection is enabled in the preferences. If i want to select the marker i have to go to the memory locations which is annoying for fast work. Any idea anyone? Could it be version related? If i go the the audio/region part i can select what i want. But if i select, let's say 2 markers with shift, nothing happens. And if i select a marker, nothing happens. Thanks |
Re: Can't select Marker - PT 2021.12.0
Maybe Dynamic Transport?
How can i turn off dynamic transport?
To check if that could be this or not. |
Right-click on play-bottom shows the status of dynamic transport.
i checked and dynamic transport is disabled. So i don't know what else it could be.
Well, the hard way:
Download PT Pref Trasher2 https://petegates.com/pgptprefs.html Make a backup from Your current prefs. Delete all preferences. See, if it works now. If not, restore Your former prefs. If yes, adjust them from scratch. (Pro Toos must be quit before using trasher). Good luck. |
i am now mixing a project but will try this later. Thanks!
i trashed prefs with PT prefs and still no change. weird. I don't understand.
Maybe its related to the version or PT i am using? |
Please provide your system specs. Namely whether your on Windows or Mac at what version OS.
Mac os Mojave 10.14.6 with a Mac Pro.
Pro Tools 21.12.0.97 |
2021.6 Clips/Markers Grid Select Broken | the.engineer | Pro Tools | 1 | 05-26-2022 02:26 PM |
Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output | Focuret | Pro Tools | 13 | 12-08-2021 06:26 AM |
Updated to HD Driver 2021.7.0 yet still no HD Native available to select for output | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 0 | 12-06-2021 07:25 PM |
shortcut for select to next marker | Neale Eckstein | Pro Tools TDM Systems (Mac) | 7 | 10-01-2015 07:36 AM |
Keyboard shortcut for jumping from marker to marker... | shotgunndunn | macOS | 1 | 11-28-2012 07:45 AM |
