Old 07-24-2022, 07:35 AM
zspritz zspritz is offline
Default GrooveCell Not Instantiating
I was initially really excited to see the addition of a drum machine plugin to protools. I did a fresh install of protools and installed groovecell except whenever I try to insert the plugin on a track it inserts channel strip instead. I've made sure that groovecell is activated in ilok and have tried restarting while holding shift to rescan plugins, as well as reinstalling the plugin.
Protools studio 2022.6.0
Windows 10
Curious as to if anyone else has exprienced this issue.
Old 07-24-2022, 09:13 AM
Default Re: GrooveCell Not Instantiating
Are you trying to instantiate on a STEREO INSTRUMENT track(which is where it should go)? I can't imagine why a different plugin would come up so I just tested it on my rig and it works fine
Old 07-25-2022, 07:16 AM
You'll have to forgive me, still extremely new to using a DAW and I was definitely trying to put it into a mono instrument track. Will try this after work, hopefully it's the solution I'm looking for.
GrooveCell bug? clutch Virtual Instruments 0 06-12-2022 08:41 PM
Instantiating plugins from surface? basehead617 Avid S4/S6 2 01-10-2020 06:03 AM
Instantiating plugins Miffling Avid S4/S6 2 01-13-2015 04:30 PM
instantiating plugins very slow CarNut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-07-2009 05:21 PM
PT 7.1 cs3 crashes on instantiating TDM plugins JLeigh2024 Pro Tools TDM Systems (Mac) 9 02-07-2006 04:28 PM
