Old 10-10-2010, 01:37 PM
1m1 1m1 is offline
Default MADI box recommendation please
I didn't get any replies in the TDM forum so I thought I'd try my luck here with this question...
I'm looking at getting an interface to connect to a Euphonix console and am wondering which way to go—Avid's new MADI box or the SSL XLogic Delta Link. Anyone have any experience with this and a recommendation?
Thanks
Old 10-10-2010, 02:26 PM
BradLyons BradLyons is offline
Default Re: MADI box recommendation please
There are pros and cons to each, the biggest point is that with the AVID box you have full AVID support where with a non-AVID box----well you're up the creek if there is an issue. In other words, AVID will not support you. The SSL box is a great solution for less money (off the top of my head here) and well, their stuff has always proven to be wonderful for the money!
Thank you,
Brad Lyons
www.howavl.com
Old 10-10-2010, 04:38 PM
clint bennett clint bennett is offline
I'm pretty sure the Avid MADI box also does real time SRC (which for some is a really big benefit), whereas the SSL does not.
Old 10-10-2010, 05:08 PM
Correct, Clint.
Thank you,
Brad Lyons
www.howavl.com
Old 10-11-2010, 12:17 AM
1m1 1m1 is offline
Thanks for the info guys.
Old 10-11-2010, 02:27 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
I know one place with the SSL box and it gets it's knickers in a twist going into their AmS/NEVE Digital desks occasionally.
If you get the avid box - it's far easier to jump up and down and have a tantrum if it doesn't work - rather than get the "not supported" shrug
Cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 10-12-2010, 07:59 AM
budster budster is offline
We have had an SSL Delta Link for 3 years now with a System 5 console. For the most part, it had been great. Pull ups and pull downs can some times be a bit dicey however.
Buddy
Old 10-12-2010, 11:05 AM
Doug the Brit Doug the Brit is offline
The Digi unit is nicely thought out.
Unfortunately there is an issue in v8.xx software that prevents me from deploying the units as I had hoped. They are sitting in a stack outside my office.
-Doug
Old 10-12-2010, 11:08 AM
1m1 1m1 is offline
-Doug
Do you mind describing the issue? And you are using 8.1cs1? Thanks
Old 10-12-2010, 12:00 PM
There are two issues...
1. A bug that relates to overlapping disabled outputs that kills a workflow between editorial and mix stage.
2. Slow lock times under P2 control when recording to fibre channel storage. Local storage is fine.
The propblems exist with all flavors of v8.xx that we have tried.
-Doug
HTML code is On
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
S3L and madi klaukholm VENUE Live Sound Systems 1 10-08-2013 12:50 PM
AVID MADI - connect 2 MADI units? smc917 Pro Tools TDM Systems (Mac) 4 07-25-2011 02:38 PM
MADI Connectivity delaplanemusic Pro Tools TDM Systems (Mac) 0 07-02-2011 02:53 PM
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX Juraj Bernáth Pro Tools TDM Systems (Mac) 3 09-10-2009 07:13 AM
