Old 01-20-2023, 05:39 AM
senghor senghor is offline
Default midi. recording
I am trying to record to inst track. But I want to preserve the parts I alraedy recorded.
So no erase.
Thanks.
Win10 Home
Intel i7-127000K @3,6GHz, RAM 16GB
UA Apollo Solo and pre-amps, Pro Tools 2022
Old 01-20-2023, 08:18 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: midi. recording
Are you talking about recording MIDI on top of a clip you previously recorded?
In order to do that, you need to enable MIDI Merge, which can be found on the transport bar.
From the manual:
The MIDI Merge button, located in the Transport
window, determines how MIDI is recorded when
overdubbing or punching in. When MIDI Merge is
on (Merge mode), recorded MIDI is merged with
existing track material. When MIDI Merge is off
(Replace mode), existing data within the punched
clip is replaced by the newly recorded material.
Will
System Details
Old 01-20-2023, 05:27 PM
Remember that Instrument tracks also can record multiple Playlists. They just cannot be auditioned as easily as possible on Audio tracks. Another easy work-around is to cut/paste existing midi onto un-assigned midi tracks used as "place keepers"
Old 01-23-2023, 03:17 PM
s.d. finley s.d. finley is offline
You could always put the midi pieces you want to keep on an actual MIDI track and have that feed into the VI via an Instrument track and then overdub on the actual Instrument track. This way you preserve the MIDI information you want without accidentally overdubbing on top of it. Consolidate when you have the pieces you want.
sdf
www.sugarhillstudios713.com
Disabling MIDI patch changes, when recording MIDI through the Eleven Rack? amnesian48 Eleven Rack 2 04-07-2014 01:58 PM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
Midi recording - I hear no audio, I am new to midi recording Peter Roberts MIDI 13 08-19-2007 03:15 PM
Digi, When Protools creates MIDI regions after recording MIDI info.... Mt.Everest Pro Tools TDM Systems (Mac) 0 07-21-2001 12:12 AM
MIDI Recording in Win98 Protools LE and keyboards...Can I use non-General MIDI sounds Shan Plourde General Discussion 2 01-18-2001 08:34 PM
