Old 11-10-2022, 01:26 PM
kinghand kinghand is offline
Default How to connect my computer to S4 display module?
I see someone connect his computer to the S4 display and make it display the computer screen content. Does anyone know how to do this? I would like to turn my S4 display to a computer screen too.
Thanks!
Old 11-10-2022, 10:30 PM
lucienpalmer lucienpalmer is offline
Default Re: How to connect my computer to S4 display module?
You can't do that. The Display Modules are more than just a screen. They have their own processor and OS.
I would suggest putting a small screen on a monitor arm, or using an iPad with Sidecar. If you do the former, you can get affordable screens on Ebay that are about the same size as the S6 display modules, and probably blend right in with the look.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 11-11-2022, 04:30 AM
I see.
Old 11-11-2022, 07:23 PM
creativecontrol's Avatar
You can however connect the DisplayPort on the Master Module and mirror it to an external rotated panel to show the same output.
On my Master Module I run a combination of Tight VNC + Remote Ripple (client Mac side) to share the Master Module screens when performing screen sharing, such as for Zoom webinars.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-12-2022, 09:15 AM
best,
Jeff
Thank you. What I was trying to do is to display the computer content on S4. Because I can't get use to look at those waveform on it.
通过我的 Mi 10 Pro 上的 Tapatalk发言
Old 11-13-2022, 01:34 AM
Nico Berthold Nico Berthold is offline
Well, that would be the most expansive 12" Computer Screen I can think of
In this case I`d rather sell the Display Module and get a screen that fills the Gap of the Display Module.
There is this Company Beetronics, making all kinds of small size monitors. I am using their 12" 4:3 Monitor for my RTW external meters, and they look a lot like the Display Modules.
Can send you a pic later if you like to see how they compare to the Display Module.
Old 11-16-2022, 04:45 PM
That would be great! Thank you!
I do see two ports under the display module screen which look like DP port. I wonder if I can connect it directly to my computer. So that I can try it first. In case I regret after selling the display module.
Old 12-02-2022, 05:48 AM
Depending on which Master Module you have, you will indeed see DisplayPort and various other ports.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Display module - clips in a folder track lucienpalmer Avid S4/S6 5 08-05-2022 02:43 PM
Post Display Module setup lucienpalmer Avid S4/S6 5 12-12-2021 01:14 PM
Post Module Display Pec/Dir Gregor B. Avid S4/S6 1 03-10-2021 05:04 AM
Changing Display Module Views From the Surface itsmemagic Avid S4/S6 6 10-19-2019 03:49 AM
Where do I connect the line out of my sound module to on 001? footuie MIDI 2 04-06-2003 11:43 AM
