Old 07-05-2021, 10:47 PM
tmuzik tmuzik is offline
Default Dynamic Plug-In Processing is broken [PT-279941]
The Dynamic plugin Processing does not work as advertised on audio tracks.
In an empty session, load up 16-60 instances of your favorite CPU hog plugin across 16 or more audio channels. Load enough so you can see a decent amount of cpu usage in the meter... wait for the cpu spike to return to normal.
Press play and the cpu meter will jump up and not return to null until you press stop.
-- Don't use Slate VMR, MeldaProduction or SoundDeviceDigital plugins b/c they have dynamic processing built into them.
Avid, Waves, Plugin Alliance, TDR etc. don't ever save CPU cycles... and are active the entire time the transport is playing.
Who is John Galt?
Last edited by tmuzik; 08-15-2021 at 07:11 PM. Reason: .6 is not relative anymore - title changed to 2021.7
Old 07-05-2021, 10:58 PM
Teej Teej is offline
Default Re: 2021.6 Native - Dynamic Plugin Processing Broken
Speculation: Are any of the plugins that remain active generating noise? Turn off all "analog" noise, in PA plugs it's V-Gain.
Maybe even 24-bit dither could be leaving a plug on?
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1
Old 07-05-2021, 11:41 PM
No analog emu's on.
Issue will be present with any avid plugins, I used the pro comp and pro limiter.
I used 16 st tracks and about 3 instances of each on all 16 tracks
I believe that ticked my i7 imac to about 30% @44.1 with 128 buffer.
Who is John Galt?
Old 07-06-2021, 08:09 AM
Fidelis Fidelis is offline
Ouch... we should all test this before any false alarms. Did you load a prior version to 2021.6 to do this test with the same session?
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 07-06-2021, 09:34 AM
One thing to remember is that plugins won't be "released" until 8-10 seconds of blank(and "blank" means no audio clip, not just a clip showing no wave)
Old 07-06-2021, 12:32 PM
That's just it - they don't release... ever. Plugins fire up to full blast on empty audio tracks when the transport in engaged.
Use a completely brand new 32 audio track empty session. Load up a bunch of AVID plugs (enough to give a clear visual on the system meter). Hit play.
Who is John Galt?
Old 07-06-2021, 01:23 PM
resonatee resonatee is offline
yes, it is not working as advertised in 2021.6 nor (i dare to say) any previous version from 2020. So it is a long standing lack of 'feature'. Shall we all report this so it will get the spotlight ADC on sends got that got 'fixed'?
Old 07-07-2021, 03:25 AM
underground123 underground123 is offline
Also confirming it is not working on my version 2021.3.
Old 07-07-2021, 05:34 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Afaik it depends on the plugin, but by far most of them don't work.
One that actually does work is Acon Digital Verberate and I believe Phoenixverb. But that's just 2 out of 18 tested (including a lot of Avid plugins). Tests are done on tracks, not auxes (for testing purpose).
/edit, running PT Ultimate 2019.6, but it's been like this since I remember. 2021.6 didn't break anything, it never worked in the first place.
Old 07-08-2021, 12:27 AM
Basstian Basstian is offline
can confirm this one. Not working here either. With stock AVID Plug-Ins.
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5
Mac OS 10.15.7
ProTools Ultimate 2020.11
Video Slave 4.3.477
Dynamic Plug-in Processing jkess Pro Tools 12 6 09-04-2019 12:35 PM
Dynamic Plug In Processing - 9173 etc. T-Low Pro Tools 2018 1 01-09-2019 01:22 AM
HEAT + Dynamic Plug in Processing in 12.6 T-Low Pro Tools 12 0 09-29-2016 12:44 PM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 09:05 AM
Is Dynamic Plug-in Processing messing up some VI's Touchwood Studios Pro Tools 11 2 11-19-2013 02:09 PM
