I've installed Pro Tools Intro on my Windows 10 laptop. I have a Roland V-Drums TD-07 electronic drum kit. It is currently plugged in to my laptop through USB, but I'm having trouble getting Pro Tools to recognize it. I'm not seeing it in the Playback Engine to set it as the Input device. I'm ok with just recording it through one track for now, just for simple recording.
I could not find any existing threads that helped with this setup. Could anyone help get me started? Any help is much appreciated, thanks. |
You need to change a setting in the TD07 module as well as having downloaded the driver for Windows. It will only show up as a stereo interface. It’s all in the manual
Is this a new Roland kit, or a very old Roland Kit? If its old, then it probably cannot act as an interface(new, I don't know). In any case, another thing you need to do is go to(in Pro Tools) Setup>Midi>Midi Studio and create a new instrument, name it as you like, and(the crucial setting), set the Input Path. Assuming the Roland drivers are installed, it would probably appear on the list as"
Roland TD-07 on USB[Emulated] Doing this tells Pro Tools where to "look for" incoming midi data(guessing you would want to record the midi from the Roland?) In the future, when you have questions like this, remember to include some basic info on the setup(Computer, OS, any/all interfaces, etc). My instructions above are for Windows users and might be a bit different for a Mac user ![]()
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Thanks for the quick response. I'll review the manual if it lists it there. Is the link to the drivers also included there or should I just search online for it?
![]() Quote:
![]() Quote:
Thanks for the quick response. I'll review the roland manual if it is listed there. |
![]() Quote:
My system is Windows 10, and no issues following your instructions, thanks. |
![]() Quote:
So which do you want? Do you want to use your module as an audio device, MIDI device, or both?
![]() Quote:
To use the drum sounds from the Roland module, things get a little more complicated. In that case, I would go "old school" and create a midi track(which, by default, should receive midi info as soon as its put into record-ready), and then use a stereo Aux track, or stereo Audio track(if you choose to use an Audio track, put it in Input mode by clicking the green "I" button). If the Roland module is set as the Audio Engine(Hardware menu?), then the Roland should be an available input choice(maybe the ONLY choice, I don't know how the TD-07 works as an interface). Assuming you want to record more than just drums, you may find adding a separate audio interface to be a better option(that would add dedicated audio inputs where you could connect audio outputs from the Roland, as well as microphones or DI'd instruments like guitar and bass).
![]() Quote:
Using a MIDI track, I'm able to see the Roland TD-7 as Input, but I can't see sound going through. I put it in record mode but it's not recording. I attached a screenshot of the MIDI track. Let me know if I can attach any more screenshots that could help in troubleshooting, thanks. |
trying to run roland v drums into the pre's in the c24 | dcooka | Getting Started | 7 | 08-03-2013 04:45 AM |
Pro Tools SE and Roland TD9-K2 V-drums | CJohn364 | Pro Tools SE and Essential (Win) | 3 | 01-04-2012 09:54 PM |
anyone Using Oceans way drums and Roland v drums? | bonzerboy | General Discussion | 2 | 10-06-2010 09:45 AM |
Oceans way DRUMS and roland v drums | bonzerboy | Virtual Instruments | 1 | 10-06-2010 09:17 AM |
Anyone Using Roland TD-9 Drums with Steven Slate Drums? | Troy Tracks Studio | The Drum Room | 2 | 05-05-2010 06:55 AM |
