Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 11-22-2011, 01:31 PM
CJohn364 CJohn364 is offline
Unhappy Pro Tools SE and Roland TD9-K2 V-drums
I installed PTSE successfully on my laptop along with the M-Audio MobilePRE interface. Got sound and can record stuff from my electric guitar. I'm more of a drummer than a guitarist, though, and I have a set of Roland TD-9K2 V-drums and would like to record drum tracks WITHOUT resorting to a MIDI controller (which I do not have). In the description for the MobilePRE, it states that I can hook up a drum machine through the 1/4" inputs in the back of the interface. I'm hoping that a set of electric drums would qualify as a drum machine. I can connect the V-drums to the interface using the 1/4" inputs and when I hit a pad the green lights on the interface light up so I know the signal is getting there, but I can't get any sound or signal to register on PTSE. I've looked through the help menu and the user manual, but couldn't find any help. I couldn't even just call tech support because I couldn't find a phone number. I would like help with trying to set up PTSE for real time recording from my Roland drums. How do I do this?
Old 11-23-2011, 02:51 AM
Default Re: Pro Tools SE and Roland TD9-K2 V-drums
No one? Ok, if I need to use a MIDI controller/interface, which would be a good recommended one?
Edit:
I've been hearing a lot about drum plug ins, such as Ezdrummer, will using one of these work in conjunction with PTSE?
Old 01-04-2012, 07:03 PM
MardukAU MardukAU is offline
Im in the middle of setting up the same thing but with the Yamaha DTX-540 kit. Will let ya know how i go.
Old 01-04-2012, 09:54 PM
I got it working. I went from the 2 x Outputs on the Yamaha DTX-500 to my M-Audio Fast Track Pro front inputs 1 & 2. Loaded up Protools SE
Make sure you click on the "Record Enable" button on the Audio Track and you should get the sounds outputted from the Roland Kit through PTSE.
You can also run MIDI for more options.
Good Luck.
anyone Using Oceans way drums and Roland v drums? bonzerboy General Discussion 2 10-06-2010 09:45 AM
Oceans way DRUMS and roland v drums bonzerboy Virtual Instruments 1 10-06-2010 09:17 AM
Anyone Using Roland TD-9 Drums with Steven Slate Drums? Troy Tracks Studio The Drum Room 2 05-05-2010 06:55 AM
Roland V-drums Mariner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 03-21-2009 05:52 PM
OT: Roland V-Drums cwhite771 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-06-2004 04:22 PM
