Old 05-25-2022, 08:05 AM
thierryhenry thierryhenry is offline
Default Edit > Separate at Transients not working
Since the Pro Tools Studio update, the separate at transients feature isn't working (see images below). The clip is being separated quite a while after the waveform begins.
Has anyone else noticed this issue, and is there a known fix for this at the moment?
I'm on Pro Tools 2022.4.0
On a 14-inch MacBook Pro, running Monterey 12.4, M1 Pro, 16 GB unified memory.
Old 05-28-2022, 10:04 AM
Default Re: Edit > Separate at Transients not working
Little bump on this one because it's causing me a lot of extra editing work that I didn't used to have to do on older Pro Tools versions.
I'm using tab to transients instead and the cursor is landing about 0.2 seconds into the waveforms.
Has anyone heard of this issue before? Are there any workarounds you can think of?
Cheers, D
Old 05-28-2022, 08:28 PM
s.d. finley s.d. finley is offline
I am noticing this too. Not on every Tab to Transient but the majority.
MBP 2020 OSX 11.6.2 PT Studio 2022.5
sdf
www.sugarhillstudios713.com
Separate Selection at Transients vs Beat Detective YYR123 Pro Tools 12 2 12-07-2015 10:48 AM
How to separate at transients for the WHOLE GROUP of tracks at once?? kaiwelch macOS 5 03-17-2014 09:37 PM
edit select permanently separate from playback; pref setting not working john john Pro Tools M-Powered (Mac) 1 12-11-2009 09:03 PM
Feat. Request - Shortcut for Separate Region at Transients Starcrash Post - Surround - Video 15 12-31-2007 03:52 PM
PT7 Separate Region by Transients function query gonzolagonda Pro Tools TDM Systems (Mac) 1 12-13-2005 02:03 PM
