creating DAE objects
Hey all
i know this has been mentioned before, as i have already done some searching.. but i cant figure out to get overcome this problem. When i am booting up pro tools, it freezes on Creating DAE objects. is this a software problem? 002 problem or PC problem?? i have managed to get pro tools to load once, after reinstalling digi drivers, but after a reboot, same old problem. any ideas on how to overcome this. I am running Win XP. pro tools 7.1 Thanks all!! Dan |
Re: creating DAE objects
I have the same problem, I had a MBox 2 and worked perfectly, i recently bought 003 factory when i insalled everything after rebooting launched pro tools and worked. But now i wanted to start working in a new session it just get stucked in "Creating DAE OBJECTS". I have installed and reinstalled 4 times, when i run it after installing it works but if I reestart my coomputer it willget stucked again. I have installed the latest Pro Tools update and my antivirus is OFF. Please help! Processor Model : Intel(R) Pentium(R) 4 CPU 3.00GHz Speed : 2.99GHz Performance Rating : PR3981 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Internal Data Cache : 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size, 2 lines per sector L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Dell Inc. A01 System : Dell Inc. Dimension 9100 Mainboard : Dell Inc. 0X8582 Total Memory : 1023MB DDR2-SDRAM Chipset 1 Model : Dell Computer Corp 82945G/GZ/P/PL Processor to I/O Controller Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 1GB DDR2-SDRAM Memory Bus Speed : 4x 133MHz (532MHz data rate) Video System Monitor/Panel : Monitor Plug and Play Adapter : RADEON X300 SE 128MB HyperMemory Adapter : RADEON X300 SE 128MB HyperMemory Secondary Physical Storage Devices Hard Disk : ARRAY CD-ROM/DVD : HL-DT-ST DVD-ROM GDR8163B (CD 48X Rd) (DVD 6X Rd) CD-ROM/DVD : PHILIPS DVD+-RW DVD8631 (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr) Logical Storage Devices Hard Disk (C:) : 295GB (198GB, 67% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A CD-ROM/DVD (E:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801GB USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801GB USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801GB USB Universal Host Controller - 27CA USB Controller/Hub : Intel(R) 82801GB USB Universal Host Controller - 27CB USB Controller/Hub : Intel(R) 82801GB USB2 Enhanced Host Controller - 27CC USB Controller/Hub : Concentrador raÌz USB USB Controller/Hub : Concentrador raÌz USB USB Controller/Hub : Concentrador raÌz USB USB Controller/Hub : Concentrador raÌz USB USB Controller/Hub : Concentrador raÌz USB FireWire/1394 Controller/Hub : Fabricante de la controladora de host compatible com OHCI IEEE 1394 Keyboard : Dispositivo de teclado HID Mouse : Mouse compatible con HID Human Interface : Dispositivo de interfaz humana USB Human Interface : Dispositivo de interfaz humana USB MultiMedia Device(s) Device : Edirol DA-PCI Communication Device(s) Device : Intel(R) 537EP V9x DF PCI Modem Printers and Faxes Model : Fax Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Hey Guys,
Try trashing your databases and preferences. Dave
Intel Core 2 Duo E6600/Asus P5W DH Deluxe/Nexus NX-5000/2 X 1GB CORSAIR PC2 6400/WD 80 & 250 GB Hard Drives/GeForce 7600GT/Lite-On CDRW/AcoustiCase 360/2-120mm AcoustiFans/XP Pro SP2/Mbox LE 7.3.1 |
I think i finally undertood what is this all about. It seems (or at least in my case) the PC detects the 003 but when you launch protools there is not enough communication (?) or it's not communicating properly between the PC/003 & Software. My solution? unplug and plug the Firewire cable from the port. I have done it at least 10 times and it worked, the only problem i have is, i dont want to [bleep] up my firewire ports by doing this everytime. Does anyone with a similar problem? |
CREATING DAE OBJECTS quits pt hd | hectorjr | Pro Tools TDM Systems (Mac) | 1 | 03-19-2012 07:56 PM |
PT 7.4.2 hangs on creating DAE Objects. | mikeyb91599 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-19-2009 03:57 PM |
PT 7.4.2 hangs when creating DAE objects | mikeyb91599 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-29-2009 05:57 AM |
creating dae objects....... | PTOOLER74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-23-2008 07:54 AM |
creating DAE Objects | euphjazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-29-2004 02:40 PM |
