Midi Timing and Sync
Hello,
I have a question about Midi set up and timing. And forgive my ignorance. I want to optimize my current set up. I realize this is an ongoing issue with many systems. I am getting pretty bad midi timing problems when I record my midi tracks to audio tracks. There are tons of beats that are off after I record the audio. I write my parts in Pro Tools which feeds Giga Studio on a seperate PC. When I’m done writing, I record the output of the Giga (PC/Delta 1010) into Pro Tools. I check the notes in Grid Mode and most of the notes are slightly late in varying degrees. I can move the whole track at one point but then the rest (because of the variations) are all off (some ahead, some behind). I’m fairly new to Midi timing protocols. I do not have any kind of sync set up between my Pro Tools rig and my samplers. Should I set up Word Clock or some other kind of sync to eliminate most of these issues? Pro Tools 6.1 HD 3 (1) 96 I/O Mac G4 867 (700MB RAM) OSX 10.20.46 Recording @ 96Khz Midiman 2x2 Midi Interface GigaStudio 96 v2.2 PC Pent 3 1 Ghz Delta 1010 (Midi in, Audio out @ 48Khz) Any tips are greatly appreciated. Thanks! Zunam |
Re: Midi Timing and Sync
In the preference dialoag, there should be a "midi offset", you need to set a negative value on this. I have noticed that doubling the amount of your HW buffer, is a good start, negative of course....your milage may vary
hope this helps sdf |
Thanks! I'll give that a try!
Sync issue, pro tools MIDI and MIDI controller, timing issue | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-29-2011 07:57 AM |
PT8.0.3 public beta Windows7 midi sync(timing) problem | Blossi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-30-2009 09:19 AM |
Midi Timing Delay Sync Issue: MTC Sync | daysean | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-22-2007 11:48 AM |
Sync Timing Off Please Help !!!!!! | dizzove | Tips & Tricks | 0 | 07-07-2005 09:08 PM |
Difference in Sync Timing between PT and DAT? | K-Wolf | Pro Tools TDM Systems (Mac) | 1 | 01-05-2001 06:06 AM |
