Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 10-16-2021, 03:13 AM
Armando Armando is offline
Default MTRX Studio and AES??
Hello! How are owners who need to incorporate AES outboard gear with their MTRX Studio accomplishing this? Adat to AES converters I assume. If so which products are you using successfully? Thanks in advance!!
Armando
Old 10-16-2021, 04:21 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
Default Re: MTRX Studio and AES??
You can also use Dante to AES. There are more channels available on Dante than on ADAT, which is handy if you have a lot of AES gear.
There are Dante converters that will do just one AES to Dante and others that will do e.g. 8 AES to Dante. Just be aware that many of the single AES to Dante converters use SRC which can not always be disabled.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 10-16-2021, 07:02 PM
BScout BScout is offline
RME converters (ADI-192 DD)
Old 10-17-2021, 04:11 AM
uptheoctave uptheoctave is offline
Simplest solution:
https://pro.focusrite.com/category/a...dnet-d16r-mkii
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 10-17-2021, 02:31 PM
RobertDorn RobertDorn is offline
I find this a weird oversight on the MTRX Studio, not having a 2-channel digital connection , being it spdif or AES, next to the adat ports (which cannot be switched from adat to optical spdif)
DSP speakers systems are in a lot of studios nowadays and it's best to feed them digitally. Of course you could add it with DANTE, but then your default monitor path will always have a little more latency than it would have had when the connection was just present on the interface.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 03-31-2023, 03:46 AM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Will this work?
https://brisound.com.au/products/aud...EaAmcFEALw_wcB
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
AVID TB3 1 slot PCie Chassis
Old 03-31-2023, 05:11 AM
nedd nedd is offline
Mutec MC-4
https://www.mutec-net.com/product_mc-4.php
___
Mac Studio Ultra, OS 13.6.5 MTRX Studio, PT Ultimate 2023.12.1, HDX1, Sync HD, BM Decklink Extreme 4K, Genelec's 9.1.4, Dolby Atmos Renderer, Avid Dock, S1, SoundFlow, Streamdeck
Old 03-31-2023, 12:01 PM
Originally Posted by anguswoodhead View Post
Yes. That will convert Dante to AES. There are sample rate limitations though. You can configure the added latency to be 1ms-5ms (you do that in Dante controller.) And, most important, you need a POE switch or a POE power injector (if not using with a switch with POE ability or if using direct.) It won't run without power.
Old 04-01-2023, 01:51 AM
OR, if you don't need HDX, take a look at the brand new DAD AX Center, 256 channels of Thunderbolt at only 95 microseconds latency, 256 channels DANTE at 48Hkz (128 at 96Khz) and the option to put in a 16 channel AES card :)
Love to see what DAD is doing with their interfaces. And actually a little pitty that the AVID branded OEM products by DAD slowly begin to live in the past regarding connectivity.
Old 04-01-2023, 02:59 AM
That box is going to cost you US$4k and the AES Card is going to cost you $1900. And they won't be available until near the end of the year.
And you'll still be short 16 AD inputs and 14 DA outputs compared to the MTRX Studio. If you don't need Thunderbolt versatility or Dante/digital input/out high counts and you do use PT HDn/HDX, the MTRX Studio is a better buy. (In the AX Center box, you can't get to the DA/AD count found in the MTRX Studio. The Studio maxes out at 20 ADC and 22 DAC. The AX Center has 2 ADC and 8 DAC on the box and then you can only get 16 more channels if you used both slots for analog. And that's at a much higher price)
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
Help - PTU can't see MTRX Studio via HDN TB3 Hud Pro Tools | MTRX & MTRX Studio 6 06-21-2021 12:32 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
