Old 04-19-2010, 05:05 PM
ericlees ericlees is offline
Default mtc and midi machine control
hi, how do i sync pro tools m powered with another computer using mtc or midi machine control?
Old 04-19-2010, 10:25 PM
DJ Hellfire DJ Hellfire is offline
Default Re: mtc and midi machine control
I would use MTC.
For your first rig as the master device - In Pro Tools of your first Master rig:
1) Use a MIDI cable to connect the MIDI OUT of your first 003 to the MIDI In of your second interface.
2) Go to the Setup menu and choose “Peripherals…”. Click on the Synchronization tab and set “MTC Generator Port" to the corresponding MIDI output port going to your slave rig.
3) Go to the Setup menu and choose “Session". Set "Time Code Rate" to 30.
4) If your Transport window is not already open, open it by going to the Window menu and choosing “Transport”.
5) Go to the View menu and highlight Transport. Choose Synchronization and click on the GEN MTC that appears on the Transport window.
In Pro Tools of your Slave rig:
1) Go to the Setup menu and choose “Peripherals…”. Click on the Synchronization tab and verify that “MTC Reader Port" is set to Any.
2) Go to the Setup menu and choose “Session". Set "Time Code Rate" to 30.
3) If your Transport window is not already open, open it by going to the Window menu and choosing “Transport”.
4) Put Pro Tools online by pressing the Online button on the far left of the Transport window. This will be verified by a blinking blue online button.
5) Press play in the master rig and the slave rig should now be playing along with Pro Tools.
NOTE: When using MTC, you should add 1 or 2 bars of blank pre-roll on both rigs.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 04-20-2010, 09:01 PM
great, why do i have to add 1 o 2 pre roll bars? so... finally i will be able to use pro tools for audio and logic for video playback and i don't need to have satellite yeah!!!
Old 04-20-2010, 09:40 PM
The pre roll is to give the two rigs time to sync. MTC takes a couple of seconds to lock in, unlike midi clock which syncs instantly. But MTC has less tendancy to drift out of sync overtime. If you don't use the blank pre roll with MTC, your first couple of seconds of audio will not playback/record.
Also, those instructions are for two Pro Tools rigs. For logic, you're gonna have to adjust the instructions to suit!
Pro Tools 2021.12
Old 04-20-2010, 09:54 PM
ok, thanks...i'll try it soon...
Old 04-30-2010, 01:16 PM
thanks i sync it with logic pro and works nice...
MIDI MACHINE CONTROL HELP!!! ez dollaz Pro Tools M-Powered (Mac) 0 08-31-2007 02:37 PM
MIDI MACHINE CONTROL - MMC Keeron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-18-2007 08:28 PM
Midi Machine Control taylor_s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-29-2005 01:48 PM
Midi Machine Control HELP taylor_s MIDI 0 06-28-2005 10:26 PM
Midi Machine Control ... carlone Pro Tools TDM Systems (Mac) 0 01-03-2005 10:05 PM
