Work flow in Pro Tools
I am a new Protools user. I used creamware tripple dat a few years back and have not done much audio editing ever since. I am a classical musician and generally work in a non MIDI environment I would like to know any suggestions regarding workflow for selection of takes, preliminary arranging of takes and cutting. One of the questions is whether it is a good idea to work with one mastertake and insert corrections into it, or whether I should assemble the final product in sequential order by creating single regions from the sound material available? Can someone recommend any tutorials on the web to find answers to those questions? Thank you Berthold Hamburger |
Re: Work flow in Pro Tools
Hi Berthold,
Hopefully someone will suggest some online tutorials, but here's my two cents on your question. Depending on your gear / studio space / level of your musicians, it can be a good idea to record a solid, fluid take and edit as necessary, especially if the songs have a strong rhythmic foundation. You can then overdub solo and melodic instruments over it. As general advice, making sure your tracks have clear names is key, and keeping note on paper of what takes were acceptable is important, especially if you are using loop record. Pro Tools sequentially numbers takes on loop record so it's straightforward to know the name of a region while it's being recorded. |
Have a look at :
http://www.howaudio.com Lots of great video tutorials were they explain in detail How to do What.... There is an PT LE essential video-tut which is absolutely superb in my view.... Dutchmountain
Artist Mix, Artist Mc Control, Pro Tools, Cubase, Imac 27” |
Change of work flow. . . . | Soundtrack2life | Pro Tools TDM Systems (Mac) | 14 | 09-09-2010 07:31 PM |
Help with work flow - Canon Camera / Pro Tools | mikevarela | Post - Surround - Video | 3 | 04-03-2008 03:13 PM |
Work .. erm .. flow ? | Bobbers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-15-2007 03:41 AM |
D-Command mix-work flow | FredrikThomander | ICON & C|24 | 3 | 07-20-2007 04:12 AM |
FCP and Pro Tools work flow. New to this. | Seeee | Post - Surround - Video | 7 | 06-06-2005 08:42 AM |
