Old 05-05-2021, 03:04 PM
ramonetl ramonetl is offline
Default Kemper DI recommendation. To Pre or not to Pre? That is the question I ask Thee. :)
Hi all, I did some researching for the best practices for when I record guitar tracks from my Kemper regarding a clean DI track of the unaltered track. In the past I would run this one of the analog preamps channels in my apollo 8 and stick a unisom pre into it to boost the signal to be hot enough so later I could reamp etc if I so chose. The primary track is via S/PDIF btw. Recently after watching a video on an engineer saying always take a clean di of your guitar tracks (in case I suppose) I got to wondering if I should just be going in as is with no preamp boost since the level later may be rerouted to say an amp sim in UA plugin or back into the kemper as another amp rig. I think since I am not making it very hot I should be fine this way but figured better to ask that find out i am later gonna clip things. I did search for this but no one covered what to do with the signal past how to hook it up etc. Thanks. PD
Old 05-05-2021, 05:04 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Kemper DI recommendation. To Pre or not to Pre? That is the question I ask Thee.
Well I just record the direct guitar signal to a track at a good level that doesn't distort. If I go to reamp, I can adjust the level at different places - in the DAW, at the interface mixer, at the reamp box, at the effects pedal, or the amp itself. If you're running the signal through multiple pre's (real or virtual), the only reason I can think of for doing this is to alter the sound according to the preamp(s) you're running it thru. You should be able to get a good recording level with a single preamp.
If your signal is clipping, you should see it in the meters and/or waveform, and you'll probably hear it if you solo the DI track.
I wouldn't overthink it, it's really not that complicated of a process IMHO.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-05-2021, 11:25 PM
Marsdy Marsdy is offline
If you’re using a Kemper this might help:
https://www.kemper-amps.com/forum/in...eamping-guide/
There’s also stuff about how to reamp in Kemper manual.
Dave Marsden
UK
Old 05-06-2021, 06:01 PM
I actually followed this before it was really useful. Was just wondering if I should boost the DI initially or later when I reamp. Thanks. I think what I was doing was already fine.
Anyone here with a Kemper? bredo Eleven Rack 0 03-08-2013 05:05 AM
Clip Based Gain... Oh How I Love Thee! EarHole Post - Surround - Video 3 04-07-2012 01:59 AM
Anyone got a Kemper? Vercingetorix Eleven Rack 53 02-16-2012 07:05 PM
External Firewire Hard Drive Question/Recommendation? heygermandude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2011 01:26 PM
Doc Queen of Phase, I Invoke Thee moosemaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-29-2002 04:50 AM
