Old 04-13-2021, 12:05 PM
SomeOtherGuy SomeOtherGuy is online now
Default Pitch question
I knew this once, but...
What the best way or best plug-in to pitch something up an octave AND have it play twice as fast--like a tape recorder would?
Thanks--
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 04-13-2021, 01:22 PM
Ben Jenssen's Avatar
Default Re: Pitch question
Just shooting from the hip, here; export file as half sample rate, and re-import without convert sample rate?
Old 04-14-2021, 04:32 AM
Thanks--
You could do it with Falcon using it's pitch and time shifting sampling capabilities. Pull the file into one of Falcon's sampling algo's and have at it.
Old 04-14-2021, 04:49 AM
I just tried what I suggested before; Select whole-file in clip bin, export in clip bin menu, set sample rate to half. Import the file, in import options click"add" not "convert", you get a warning that it will play back at wrong speed, which is exactly what we want. Couldn't be simpler.
Old 04-14-2021, 05:36 AM
midnightrambler midnightrambler is online now
Thanks--
Use Elastic Audio on “varispeed” and set the "TCE Factor" to 50%. Much easier than all the faffing that other people are describing.
Old 04-16-2021, 12:12 AM
simonchase simonchase is offline
Use the "Pitch Shift Legacy" plug-in, included with Pro Tools. But make sure you uncheck the "TIME CORRECTION" box in the middle of the plug-in.
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 04-16-2021, 10:11 AM
smurfyou smurfyou is online now
The included Time Shift plugin has a varispeed algorithm. No need to export or use 3rd party tools.
~Will
Old 04-16-2021, 10:24 AM
Great, thanks a lot everyone...
Old 04-16-2021, 05:31 PM
matchmix matchmix is offline
I use elastic pitch for that
Old 04-17-2021, 06:16 AM
cwsand's Avatar
cwsand cwsand is offline
+1
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Audio Pitch Question Wavelabs Pro Tools M-Powered (Win) 6 04-21-2011 08:57 PM
Elastic Pitch Question RichrdC Pro Tools M-Powered (Win) 7 01-24-2010 08:03 PM
elastic Pitch Question DonaldM Tips & Tricks 9 05-26-2009 06:48 PM
Pitch Question!! Rampage 14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-03-2006 12:31 PM
Pitch Shift Question Kakalaka Koffee Pro Tools TDM Systems (Mac) 11 04-30-2002 10:50 AM
