Old 05-02-2008, 10:59 AM
ay0 ay0 is offline
Default Timing problems
hey i have a macbook 2.2 ghz with 2 gb RAM and im using an MBOX 2 pro, and ive hooked up my microphone and it seems to lag a little when i hear myself in head phones and try to record, it is throwing off the timing of my lyrics. i dont kno if im using the proper terminalogy but im sorda new so bare with me. if u need any info let me know, thanks
Old 05-02-2008, 11:31 AM
drguitar drguitar is offline
Default Re: Timing problems
very simple and a very rookie thing (I mean that with no offense, I learned about this myself once too!)
you need to lower your H/W Buffer Size
Go up to the Setup menu at the top and select Playback Engine
then you'll see it
you can probably record with 256 and still be okay, but go to 128 if the delay is still too noticeable
happy recording!
iMac 2017 4K Quad 3.6 GHz i7
32 GB RAM
Presonus 1818VSL
PT Ultimate
Old 05-02-2008, 11:37 AM
citi citi is offline
Since the mbox 2 pro is firewire, it should support low latency monitoring. It's under options
CiTi
http://www.checkonet2ent.com
ay0 ay0 is offline
hey thanks alot!!
7.4 midi timing problems lifer Pro Tools TDM Systems (Win) 2 11-23-2007 06:18 AM
MIDI Timing problems with PT7.3 ?? humbuzz MIDI 1 05-15-2007 10:53 PM
midi timing problems Julianjulian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-21-2004 06:56 AM
Timing problems at 00:00:02:57 ? marcelloz Pro Tools TDM Systems (Mac) 3 04-21-2001 05:15 PM
TIMING PROBLEMS WITH MPC AND PT benhallen Pro Tools TDM Systems (Mac) 5 02-02-2001 12:43 AM
