Command|8 Going Offline
Our Command|8 has randomly gone offline. Has anyone else had this happen? If so, have you resolved it?
System: MDD Dual 1.25GHz G4, 1.25GB RAM, OS X v10.3.4, PT v6.4.1cs3, Command|8 v02.01.02 Problem: Command|8 is randomly going offline. Reproducible: Yes, but not with known steps. Workaround: Quitting and relaunching Pro Tools restores the Command|8's status to online. This is a lame workaround, especially if your session is large. Thanks for reading!
Re: Command|8 Going Offline
Have you tried a different usb port? You could allways uninstall and reinstall the drivers. I'm guessing at this point.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Are there any other USB peripherals attached to your computer?
Do you have any other midi devices connected to the Command|8? Do you have any other midi drivers installed on your computer (check in MacHD>Library>Audio>MIDI Drivers)? If so, try removing any unused drivers from that folder. Have you tried using different midi cables? |
Thank you for responding, DigiTechSupt!
Thanks for reading!
Regarding the 'midi' cable - yes, I actually meant the USB cable. Is the USB cable of normal length (6' or shorter)?
Have you tried it without the UPS connected? Since there seems to be no other logical reason for this to be happening, I have a suspicion that possibly the UPS could be a factor. I might suspect the Keyspan as well, but not as much as the UPS. Could you test it with both those devices disconnected? Did you find anything about any other midi drivers being installed? One other possibility - did you move the Pro Tools application from it's original install location by chance? The application should be located in MacHD>Applications>Digidesign>Pro Tools (the folder) along with the Controllers folder. If it was moved, that would definitely cause this problem. |
I have had this problem as well. Usually for me just power cycling the C8 does the job, without even quitting PT. I have my MIDI interface on one port, and my C8, keyboard/mouse/ilok, and printer on the other, and it works fine, for the most part.
Mac OSX 10.3.7 Dual 1.41 Gig 1 Gig RAM PT 6.7cs8 HD4 |
Thanks for your help!
Yeah im getting it here as well. i have to reset the peripherals 3-4 time a week. a real vibe buster.
john |
Another observation: Im getting a Preference reset as well. Each time the Command8 comes offline all my custom prefs are lost as well.
No thats really NOT COOL. John |
Command 8 Offline FIX | TDub | ProControl, Control|24, Command|8 | 2 | 11-20-2011 01:59 AM |
D-Command Offline | jim2step | ICON & C|24 | 3 | 04-27-2010 09:52 AM |
Yet Another Command 8 Offline | idoteech | ProControl, Control|24, Command|8 | 1 | 10-25-2008 05:16 PM |
Command|8 (Offline) | RonDaniel | ProControl, Control|24, Command|8 | 5 | 04-04-2007 09:18 AM |
command 8 REALLY OFFLINE | frewno | ProControl, Control|24, Command|8 | 0 | 10-31-2006 08:23 AM |
