Old 08-04-2021, 07:34 AM
pie55 pie55 is offline
Default importing reverbs crashes Protools
Hi
I just installed another Accel card, upgrading to a hd3 system. I mixed 2 songs and everything worked fine.
Then the 3rd song, I tried importing some reverbs from previous sessions and the session crashed. I tried 3 times and it crashes every time.
Then I tried importing the reverbs one at a time. Waves Renaissance reverb and the other Dverb crashed the session. The other verbs didn't
Anyone else experience this?
I"m using Protools HD 8.1.1 on a Mac Pro
tks
Old 08-04-2021, 07:39 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: importing reverbs crashes Protools
Is your WavesHell compatible with PT8?
Janne
Old 08-04-2021, 02:05 PM
i think so. I asked waves if the plugins were compatible with my system and they said yes. also why would dverb crash my session?
Old 08-05-2021, 08:12 AM
albee1952 albee1952 is online now
As a work around, go back to a session that uses the reverbs you want and save the settings as presets. Moving forward, instead of importing those, just instantiate fresh and recall the presets.
Old 08-08-2021, 06:33 PM
yes good idea. I came to that conclusion after I posted too.
Something else weird happened the other day. I had a few plugins on an overhead. out of nowhere the signal disappeared. only to return when i removed the Puigtech eq. strange
Old 08-09-2021, 10:53 AM
That puts you back to JFreak's question about Waves and PT8. You should be checking with Waves on which version is compatible with PT8 and your OS(which you have not mentioned yet) You might consider moving up to PT10 if your Mac will allow.
Importing AAF crashes Protools 24bit dither Pro Tools TDM Systems (Mac) 1 07-04-2009 02:41 PM
ProTools 7.4 crashes in Waves5.0.dll importing a old project Gene Cookmeyer Pro Tools M-Powered (Win) 2 12-18-2007 06:08 AM
Protools INSTANTLY crashes when importing (USB midi issue?) Pony Slaystation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2007 12:57 PM
Protools Crashes when Importing Audio?? brinaddison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-30-2005 02:04 PM
Importing Quicktime into Protools 6.4 CRASHES PT xxopexx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-03-2004 08:04 AM
