HD3 - How does it all connect??
I'm quite new at HD3 and how it all works. I'm currently running LE and am upgrading but not sure what need to go where and what needs to be purchased. I'm getting a 1073DPD, 192 I/O and the HD3. I don't understand how it all connects to eachother and what I need ie: Mbox 2 Pro has 2 phones ports + volume control 2 Xlr and 1/4 inputs + volume control What do I need to get to replicate this?? The command 8??? I'd appreciate any advice. |
Re: HD3 - How does it all connect??
Take a look at the "Big Knob" from Mackie.
Maybe somebody else knows any cheaper alternatives? (Not that the Big Knob is that expensive tho hehe) |
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
i went the Command 8 so you get the control part for the monitors and the control surface. Best of both worlds.
Start with (drum roll, please) “HD Getting Started Guide,” and the “Expanded Systems Guide,” if applicable, as well as the manual(s) for whichever interface(s) and controller you’re planning to acquire. After that, I’d recommend that you read the “Plug-ins Guide” and the “PT Reference Guide.” With the latter at hand, here’s a tip for speeding up your transition from LE. Open the pdf version of the Reference Guide and search for “HD Only”. This will quickly reveal all topics that you would have bypassed in the past as an LE user. (If your pdf documents open with Apple’s “Preview”, besure to reveal the “Drawer” from the “View” menu, or use the “Shift-Command-D” shortcut. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
any help please how to connect | alkhashti | MIDI | 1 | 07-10-2012 02:50 PM |
How can I Connect 3 192 I/O's in HD|1? | egghead | Pro Tools TDM Systems (Mac) | 4 | 11-02-2011 07:54 AM |
FW 400 to 800 connect! | ktwalker76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-13-2011 01:41 AM |
Best way to connect 002 Cpu and HD | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-15-2008 12:50 AM |
How to connect a sub to 001 | Doug Paluch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-01-2003 09:54 AM |
