MIDI recording freezes PT 6.0 & 7.0
In both 6.0 and 7.0 all PT sessions light or heavy tend to Freeze when recording MIDI (usually after 10-15 mins of seqencing).
I sequence in PT using the Mbox, Triton keyboard, MIDIsport uno, Trigger finger, NI Battery 3 and M-Audio Key Rig. I have recently gotten rid of the dual core PC and for now have reverted back to my older slower Pentium 4 512mb. Its served me well in the past with 5.3.3 so until you guys help me get this MIDI prob figured out I'll be work with this guy. SiSoft sandra report coming soon...
PT LE 7.3.1 M Box Intel Q9550 4G DDR2 Akai MPK 49 Grand Rapids/Lansing/Detroit MI hiphop head |
Re: MIDI recording freezes PT 6.0 & 7.0
sircharles2,
I posted a support case at M-Audio about my MIDI problems (same as yours) and got the following response: ++++++++++++++++++++++++++++++++++++++++++++++++ Please try testing your MIDI device with MIDI-OX (MIDI monitoring and diagnostic software) to see if it is sending and receiving MIDI data properly. This is a shareware utility you can download from http://www.midiox.com/zip/midioxse.exe Download the application and install it, then run it by itself with no other applications running. To set it up for the test: OPTIONS > MIDI DEVICES > INPUT > SELECT ALL OPTIONS FOR M-AUDIO or USB AUDIO DEVICE > OK Then try to input some MIDI data via your device, you should see a readout of information scrolling down the screen as it is received. ++++++++++++++++++++++++++++++++++++++++++++++++ Maybe this can help you -- I haven't yet done this test. Kevin |
Thanks, I'll definitely give this a try tonight.
Also, the MIDI-OX can create logs -- M-Audio support asked me to see if I run into the same MIDI "sticking" problem when running MIDI-OX. If so, I am hopeful that the log will provide some useful info.
Kevin |
Sorry for the delay dudes, I finally got a chance to properly test out the system after running those downloads, the MIDI fix and such. I'm still having the same problem. So here is a hardware report.
<<< System Summary >>> > Mainboard : Asus P4PE > Chipset : Intel i845PE > Processor : Intel Pentium 4 @ 2533 MHz > Physical Memory : 512 MB (1 x 512 DDR-SDRAM ) > Video Card : Nvidia Corp GeForce4 MX 440 [NV17.2] > Hard Disk : WDC (80 GB) > CD-Rom Drive : SAMSUNG CD-R/RW SW-252B > Monitor Type : Princeton Graphic Systems VF912 - 18 inches > Network Card : Broadcom Corp BCM440x 10/100 Integrated Ethernet Controller > Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 2 > DirectX : Version 9.0c <<< Mainboard >>> > Manufacturer : System Manufacturer >> General Information Product : System Name Version : System Version Serial Number : EVAL Unique ID : 00000000-00000000-00000000-00000000 Start mode : Power Switch >> OEM Information OEM #1 : 0 OEM #2 : 0 > Mainboard : Asus P4PE >> General Information Manufacturer : ASUSTeK Computer INC. (Asus) Product : P4PE Version : REV 1.xx Serial Number : xxxxxxxxxxx Support MP : No >> Chassis Information Manufacturer : Chassis Manufacture Type : Tower Version : Chassis Version Serial Number : EVAL Asset : Asset-1234567890 >> Sensor Information Monitoring Chip : Asus ASB100 >> On-Board Device Information Device : Broadcom LAN (Ethernet) >> Slots Information Slot PCI : Available (32-bit) 5.0v, 3.3v Slot PCI : Available (32-bit) 5.0v, 3.3v Slot PCI : In Use (32-bit) 5.0v, 3.3v Slot PCI : Available (32-bit) 5.0v, 3.3v Slot PCI : Available (32-bit) 5.0v, 3.3v Slot PCI : Available (32-bit) 5.0v, 3.3v Slot AGP 4X : In Use (32-bit) 3.3v >> External Connectors USB : Access Bus (USB) USB : Access Bus (USB) USB : Access Bus (USB) USB : Access Bus (USB) USB : Access Bus (USB) USB : Access Bus (USB) Keyboard : PS/2 Mouse : PS/2 Parallel ECP/EPP : DB25 female Serial 16550 Compatible : DB-9 male Serial 16550 Compatible : DB-9 male Joystick : DB-15 female MIDI : DB-15 female Audio : Mini-jack (headphones) Network : RJ-45 >> Internal Connectors PRIMARY IDE/HDD : On Board IDE SECONDARY IDE/HDD : On Board IDE FLOPPY : On Board Floppy 1394 Port 1 : 1394 1394 Port 2 : 1394 SATA/IDE RAID : On Board IDE > Bios : Award Software, Inc. >> General Information Manufacturer : Award Software, Inc. Version : ASUS P4PE ACPI BIOS Revision 1002 Date : 28 October 2002 Address : 0xF000 on 512 KB Copyright : Copyright (C) 1984-98, Award Software, Inc. Motherboard ID : 10/28/2002-I845PE/ICH4/IT8708-P4PE DMI Version : 2.3 >> Characteristics Flashable : Yes Socketed : Yes >> Functionality APM : Yes ACPI : Yes ESCD : Yes PnP : Yes PCI : Yes ISA : No AGP : Yes USB : Yes PCMCIA : No Smart Battery : No >> Boot Information Selectable Boot : Yes CD-ROM Boot : Yes PC Card (PCMCIA) Boot : No I20 Boot : No LS-120 Boot : No 1394 Boot : No ATAPI ZIP Boot : No Network Boot : No > Chipset : Intel i845PE >> General Information NorthBridge : Intel i845PE SouthBridge : 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge >> NorthBridge Information Architecture : HUB Manufacturer : Intel (ASUSTeK Computer Inc) Codename : Brookdale-G Revision : B0 Bus Speed : 133.6 MHz FSB Frequency : 534.5 MHz (QDR) FSB max. Support : 533 MHz RAM max. Support : DDR (333 MHz) >> Memory Information Type : DDR-SDRAM PC2700 Frequency : 167 MHz DRAM/FSB Ratio : 5/4 Activated Channels : Single ECC Diagnostic : No CAS Latency (tCL) : 2.5 clocks RAS to CAS (tRCD) : 3 clocks RAS Precharge (tRP) : 3 clocks Cycle Time (tRAS) : 7 clocks DRAM Idle Timer : 16 clocks >> Bus Information Version : 2.0 Transfert Rate supported : 1x, 2x, 4x Transfert Rate : 4x Aperture Size : 64 MB Side Band supported : Yes Side Band enabled : No AGP enabled : Yes >> Video Information Integrated Controller : No Enabled : No >> APIC Information Version : 2.00 Maximum Interrupts : 24 IRQ Handler enabled : Yes >> Hub Interface Information Version : 1.00 Time Slice : 0 Width : 8-bit Full Duplex : Yes Frequency : 4x (264 MHz) Multiplier : 1/1x >> Device Capabilities (PCI) I/O Access : No Memory Access : Yes Bus Master Capable : Yes Special Cycle Recognition : No Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : No Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : Yes PCI Support : Vendor-Dependant PCI Support : AGP > Physical Memory : 512 MB DDR-SDRAM >> General Information DIMM 1 (RAS 0, RAS 1) : 512 (Double Bank) DIMM 2 : Empty DIMM 3 : Empty >> Information SPD EEPROM (DIMM 1) Manufacturer : Kingston Part Number : K Serial Number : Unspecified Type : DDR-SDRAM PC-2700 (166 MHz) - [DDR-333] Size : 512 MB (2 rows, 4 banks) Module Buffered : No Module Registered : No Module EPP : No Width : 64-bit Error Correction Capability : No Max. Burst Length : 8 Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 2.5v Prefetch Buffer : 2-bit Manufacture : Week 1 of 2003 Supported Frequencies : 133 MHz, 166 MHz CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @166 MHz RAS to CAS (tRCD) : 3 clocks @133 MHz, 3 clocks @166 MHz RAS Precharge (tRP) : 3 clocks @133 MHz, 3 clocks @166 MHz Cycle Time (tRAS) : 6 clocks @133 MHz, 7 clocks @166 MHz >> Memory Controller Information Memory Controller : ECC, DIMM, SDRAM Number of connectors : 3 Max. Module Size : 1024 MB Max. Memory Size : 3072 MB Supported Speed : 70ns, 60ns, 50ns Supported Voltages : 3.3v Error Detection Method : 64-bit ECC Error Correction Capability : Single Bit Current/Supported Interleave : Unspecified/Unspecified > LPC bus : Yes >> Bus Information Type : ISA - LPC Device : 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge Revision : 02 Number of ISA Connectors : 0 Frequency : 8 MHz Multiplier : 1/4x DMA Speed : 4 MHz Multiplier : 1/2x >> Device Capabilities (PCI) I/O Access : Yes Memory Access : Yes Bus Master Capable : Yes Special Cycle Recognition : Yes Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : Yes Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : No > PCI Bus : Yes >> General Information Number of PCI Bus : 3 Number of PCI Connectors : 6 >> Peripheral Type Device 1, Bus 0 : AGP Device 1, Bus 1 : AGP >> General Features Support Mechanism 1 : Yes Support Mechanism 2 : No >> Bus Information #0 Device : 82845G/GL/GV/GE/PE Brookdale Host-Hub Interface Bridge Device : 82845G/GL/GV/GE/PE Brookdale Host to AGP Bridge Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB 2.0 EHCI Controller Device : 82801BA/CA/DB/DBL/EB/ER/FB/GB/HB (ICH2/3/4/4/5/5/6/7/8), 63xxESB Hub Interface to PCI Bridge Device : 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge Device : 82801DB/DBL (ICH4/ICH4-L) UltraATA/100 EIDE Controller Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller >> Bus Information #1 Device : GeForce4 MX 440 [NV17.2] >> Bus Information #2 Device : VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Device : PDC20376 FastTrak 376 SATA/RAID Controller Device : BCM440x 10/100 Integrated Ethernet Controller Device : ES2838/2839 SuperLink Modem > AGP Bus : Yes >> Bus Information Number of AGP connectors : 1 >> AGP Bus Device : 82845G/GL/GV/GE/PE Brookdale Host-Hub Interface Bridge Version : 2.0 AGP enabled : Yes Mode AGP3 : No 4GB : No FW Transfer : Yes - Enabled SideBand : Yes - Disabled Command Queue : 1 (max. 32) Transfert Rate supported : 4x Transfert Rate : 4x >> AGP Bus Device : GeForce4 MX 440 [NV17.2] Version : 2.0 AGP enabled : Yes Mode AGP3 : No 4GB : No FW Transfer : Yes - Enabled SideBand : No Command Queue : 32 (max. 32) Transfert Rate supported : 4x Transfert Rate : 4x >> Bus Information Device : GeForce4 MX 440 [NV17.2] > USB Bus : Yes >> Device Information Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB 2.0 EHCI Controller Version : 2.0 Interface : EHCI > SMBus/i2c Bus : Yes >> General Information Device : 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller Revision : 2 Frequency : 16 KHz Address : 0xE800 >> Device Capabilities (PCI) I/O Access : Yes Memory Access : No Bus Master Capable : No Special Cycle Recognition : No Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : No Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : No > Bus HyperTransport : No > Bus CardBus : No > Bus FireWire : Yes >> Bus Information Device : VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller Version : 1.00 Speed : 400 MHz <<< Processor >>> > Processor : Intel Pentium 4 >> General Information Type : Intel Pentium 4 Internal Specification : Intel(R) Pentium(R) 4 CPU 2.53GHz Codename : Northwood Revision : B0 Technology : 0.13µ CPU ID : F.2.4 CPU IDEx : F.2.4 Brand ID : 9 Microcode : MU0F241E >> Features VME - Virtual Mode Ext. : Yes DE - Debugging Extension : Yes PSE - Page Size Extension : Yes TSC - Time Stamp Counter : Yes MSR - Model Specific Registers : Yes PAE - Physical Address Extension : Yes MCE - Machine Check Exception : Yes APIC - Local APIC Built-in : Yes SEP - Fast System Call : Yes MTRR - Memory Type Range Reg. : Yes PGE - Page Global Enable : Yes MCA - Machine Check Architecture : Yes PAT - Page Attribute Table : Yes PSE36 - 36-bit Page Size Extension : Yes PSN - Unique Serial Number : No DS - Debug Trace & EMON Store : Yes ACPI - Software Clock Control : Yes SS - Self Snoop : Yes TM - Thermal Monitor : Yes HTT - Hyper-Threading : Yes SBF - Signal Break on FERR : No MON - Monitor/Mwait : No DSCPL - CPL qualified Debug Store : No TM2 - Thermal Monitor 2 : No CID - Context ID : No EST - Enhanced SpeedStep Technology : No XD - No-execute Page : No VT - Vanderpool Technology : No LT - LaGrande Technology : No >> Miscellaneous FPU - Co-processor Built-in : Yes CX8 - CMPXCHG8B : Yes CX16 - CMPXCHG16B : No CMOV - Conditionnal Move Inst. : Yes CLF - Cache Line Flush : Yes FXSR - Fast Float Save & Restore : Yes xTPR - Send Task Priority : No DCA - Direct Cache Access : No DAZ - Denormals Are Zero : Yes MMX Technology : Yes SSE Technology : Yes SSE2 Technology : Yes SSE3 Technology : No S-SSE3 : No SSE4A : No Intel64 (EM64T) : No IA-64 Technology : No PBE - Pend. Brk. EN. : No LAHF - LAHF/SAHF Inst. : No >> Features Hyper-Threading Technology Enabled : No >> Advanced Settings In Order Queue Depth : 12 Fast-Strings : Yes x87 FPU Opcode : No Thermal Monitor : Yes Split-Lock : Yes Performance Monitoring : Yes Prefetch Queue : Yes Branch Trace Storage : Yes C1E - Enhanced Halt State : No >> Mainboard Upgradeability Socket/Slot : PGA 478 Upgrade interface : ZIF Socket Supported Speed : 3200 MHz (or more) Supported Voltage : 1.5V > Frequency : 2533 MHz >> General Information Real Frequency : 2539.19 MHz Multiplier : 19x Low/High Multiplier : 19x / 19x Multiplier Locked : Yes Marketing Frequency : 2527 MHz >> Front Side Bus Information Bus Speed : 133.6 MHz FSB Frequency : 534.6 MHz (QDR) >> Initial Frequencies Frequency : 2533 MHz FSB Frequency : 133 MHz Multiplier : 19x >> Control Clock Frequency Type : None >> Thermal Information Thermal Design Power : 55.3 W Core Power : 55.44 W (estimated) Resistance : 0.5 °C/W (estimated) Thermal control TM1 : Yes Thermal control TM2 : No Thermal Control Circuit : No Digital Thermal Sensor : No ODCM Enabled : No Thermal Status : Normal >> Processor Performance Information Throttle Mode AC : None Throttle Mode DC : Adaptive Current Configuration : None Throttle : 2539 MHz >> Processor Power Management Information Processor Throttling : Yes Throttle Range : 12% - 100% Active Power Scheme : Home/Office Desk > Support : mPGA-478 > Data Cache L1 : 8 KB >> General Information Type : Pipeline Burst, Synchronous Write Mode : Write-Through Place : Internal Correct : Single-bit ECC >> Cache Information Data Cache : 8 KB (4-way, 64 bytes line size) L1 Context Mode : Adaptive > Trace Cache L1 : 12 Kµops >> Cache Information Trace Cache L1 : 12 Kµops (8-way) > Cache L2 : 512 KB >> General Information Type : Pipeline Burst, Synchronous Write Mode : Write-Back Place : Internal Multiplier : 1/1x (2539.2 MHz) >> Cache Information Associativity : 8-way Line Size : 64 bytes Bus : 256-bit Prefetch Logic : Yes > Voltage : 1.500 V > FPU Coprocessor : Present >> General Information Integrated : Yes Model : Compatible Intel > Processor activity : : 3% <<< Video >>> > Number of monitor : 1 >> Monitor Information #1 Monitor : Plug and Play Monitor Linked on : NVIDIA GeForce4 MX 440 (Microsoft Corporation) Resolution : 1280x1024 Working desktop : 1280x990 Main monitor : Yes > Monitor Type : Princeton Graphic Systems VF912 >> General Information Manufacturer : Princeton Graphic Systems Product ID : PGS026E Model : VF912 Serial Number : JCAC5200218 Manufacture : Week 52 of 2012 Video Input Type : Analogic, Sync on green in 0.7/0.3v Max. Horiz./Vert. Size : 37 cm / 27 cm Monitor Size : 18 inches (estimated) Aspect Ratio : 4:3 Gamma Factor : 2.76 DPMS Active-Off : Yes DPMS Suspend : Yes DPMS Standby : Yes EDID version : 1.3 >> Features Maximum Resolution : 1280 x 1024 @ 75 Hz Horizontal frame rate : 30 - 96 kHz Vertical frame rate : 50 - 160 Hz Bandwidth : 200 MHz >> Video Modes Supported Mode : 720 x 400 @ 70 Hz Mode : 720 x 400 @ 88 Hz Mode : 640 x 480 @ 60 Hz Mode : 640 x 480 @ 67 Hz Mode : 640 x 480 @ 72 Hz Mode : 640 x 480 @ 75 Hz Mode : 800 x 600 @ 56 Hz Mode : 800 x 600 @ 60 Hz Mode : 800 x 600 @ 72 Hz Mode : 800 x 600 @ 75 Hz Mode : 832 x 624 @ 75 Hz Mode : 1024 x 768 @ 87 Hz interlaced Mode : 1024 x 768 @ 60 Hz Mode : 1024 x 768 @ 70 Hz Mode : 1024 x 768 @ 75 Hz Mode : 1280 x 1024 @ 75 Hz >> Video Modes Standard Mode : 1280 x 1024 @ 85 Hz Mode : 1280 x 960 @ 85 Hz Mode : 1152 x 864 @ 75 Hz Mode : 1024 x 768 @ 85 Hz Mode : 800 x 600 @ 85 Hz Mode : 640 x 480 @ 85 Hz Mode : 1600 x 1200 @ 75 Hz > Video Card : NVIDIA GeForce4 MX 440 (Microsoft Corporation) >> General Information Manufacturer : Nvidia Corp Model : GeForce4 MX 440 [NV17.2] Bus Type : AGP Total Memory : 64 MB Texture Memory : 120 MB Processor : GeForce4 MX 440 Converter : Integrated RAMDAC Refresh Rate (min/max) : 56/85 Hz >> GPU Information Number of GPU : 1 Codename : NV17 Revision : A5 Bus : 128-bit Memory Type : SDRAM GPU Frequency : 249.75 MHz Memory Frequency GPU : 333 MHz Texels : 1000 MTexels/s DirectX Support : 7.0 Pixel Shader Version : 3.0 >> nForceware Configuration Supported Frequencies : GPU: 249 MHz - Memory: 332 MHz >> GPU Configuration Technology SLi : No >> Video Bios Information Date : 10/28/20 Version : Award Modular BIOS v6.0 ID : Version 4.17.00.69.00 >> i2C Bus Information Number of Bus : 3 >> General Features Width : 337 mm Height : 270 mm Pixel per inch : 120x120 dpi bits per pixel : 32 Colour Bits/Planes : 1 Brushes : 4294967295 Pens : 4294967295 Markers : 0 Device Fonts : 0 Device Colours : 4294967295 Clip Output to Rectangle : Yes Hardware Acceleration : Yes >> Blend and Shade Capabilities GradientFill Rectangle : No GradientFill Traingle : No Per Pixel AlphaBlend : Yes Premultiplied Alpha : No >> Raster Capabilities Banding : No Transfer Bitmaps : Yes Bitmap >64 KB : Yes Fonts larger than 64 K : Yes DIBs : Yes DIBTODEV : Yes Flood Fills : Yes Scaling : No StretchBlt : Yes StretchDIB : Yes >> Curves Capabilities Chord Arcs : Yes Circles : Yes Elipses : Yes Interiors : Yes Pie Wedges : Yes Rounded Rectangles : Yes Styled Borders : Yes Wide Borders : Yes Wide, Styled Borders : Yes >> Lines Capabilities Interiors : Yes Markers : Yes Polylines : Yes Polymarkers : Yes Styled : Yes Wide : Yes Wide, Styled : Yes >> Polygonal Capabilities Interiors : Yes Alternate Fill Polygons : Yes Winding Fill Polygons : Yes Rectangles : Yes Scan Lines : Yes Styled Borders : Yes Wide Borders : Yes Wide, Styled Borders : Yes >> Text Capabilities Stroke Precision : Yes Stroke Clip Precision : Yes 90° Character Rotation : No Any Angle Character Rotation : No Independent X-Y Scaling : No Double Weighted Characters : No Italic : No Underline : Yes Strikeout : Yes Raster Fonts : Yes Vector Fonts : Yes >> Color Management Capabilities CMYK : No Gamma Ramp : Yes ICM Device : No > Current Display : 1280x1024 pixels at 75 Hz in True Colors (32-bit) >> General Information Depth : 32-bit/pixel Refresh Rate : 75 Hz This is it folks, Digi let see some resolution, Thanks!
sircharles2,
I am pleased to report I was able to fix my problem. The solution is fortunately simple but unfortunately expensive -- buy a Digi MIDI I/O box. I yanked out my M-Audio 4x4, applied the MIDI Fix, uninstalled my 4x4 and installed the Digi MIDI I/O unit. I tried all kinds of things to freeze the MIDI and no matter what I tried, it worked like a charm. Things that would normally freeze up my M-Audio 4x4 quickly (like MIDI-merge) had no impact on my new Digi MIDI I/O. This tells me that indeed M-Audio USB interface are NOT completely compatible with Pro Tools. Also, note that just because Avid owns both Digi and M-Audio does not mean the products were developed together nor guaranteed to be compatible. If you want the issue fixed, get the Digi MIDI I/O. I got a good deal at Sweetwater dot com - they were very helpful -- and if the MIDI I/O doesn't fix your problem (highly unlikely) you can return the MIDI I/O for a full refund within 30 days. Thanks, Kevin |
Delgadil, thanks for the help...
For a small home studio setup perhaps Digi MIDI I/O is perhaps not the best solution considering it's cost and its unnecessarily high amount of MIDI channels (m box can only achieve so many audio files). Considering the nature of the problem and other product offerings it would make more sense for me to purchase a new M-box 2 or even a digi 002 both of which have built in MIDI. I'm glad something works and that you were able to fix your prob but I think for now I'll wait for a more reasonable solution. Hint hint DIGI, chime in when ever your ready...
No problemo -- note that if you need more than one MIDI input, neither the MBox 2 nor
Digi002 will do the job for you. That's why I originally went with M-Audio 4x4 -- because I have Roland TD-20 drums, Triton keyboard, and Proteus 2000 synth (and other MIDI goodies). I need to have all of these hooked up via MIDI simultaneously. Admittedly, the Digi MIDI I/O is overkill (with 10 MIDI ports), but I just wanted the darn thing to work. Already invested quite a bit in my Digi002 system and recording studio in general and spending the $$$ on this unit made sense for me. I love my Digi002, but one MIDI port isn't enough for me. Also, my MIDI ports on my Digi002 don't work anymore -- Digi tech support were stumped after we did all kinds of tests. I don't know if this is a common problem with the Digi002 MIDI ports, but is something to be aware of. Thanks and good luck, Kevin |
Recording Midi freezes hangs Pro Tools | jallen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2007 06:17 AM |
PT freezes when recording MIDI from MPC 1000 | Yosamite | MIDI | 0 | 03-20-2006 08:01 AM |
Midi Recording Freezes session | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-24-2006 06:58 AM |
Recording Midi freezes up PT... WHY... *HELP* | toomuch | MIDI | 1 | 04-18-2005 08:59 AM |
PT Freezes when recording midi | muzishun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-17-2004 03:00 PM |
