Old 01-21-2007, 08:20 AM
ircswh ircswh is offline
Default Plug-ins Inserts Missing in MIX? After saving.
THis has happened before . I build a project using Sample Tank and in this case Xpand!. SAve It. Open it back up and the plugins are missing in the mix. (So it looks like im not using any plugins.
It still makes the sound created by the plug in, but im not able to open it up to change what instruments i want to use because its missing. WHat causes this so i can try to prevent it from happening and How can i fix this?
Thanks in advance.
Using
M Powered 7.1
Old 01-21-2007, 03:41 PM
Stig Eliassen's Avatar
Default Re: Plug-ins Inserts Missing in MIX? After saving.
From the menu, select View > Mix window > All. This will reveal both instruments and inserts.
Old 01-22-2007, 03:58 AM
thank you!
Trouble with ADC and Hardware Inserts? Something I am missing? dwdrms Pro Tools HDX & HD Native Systems (Win) 0 12-05-2011 07:10 PM
Reason Missing after saving rickdrmmr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-18-2008 08:10 PM
Plug-ins missing in Inserts window Revolver73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-12-2007 01:36 PM
Saving Sessions and missing fade files Kevin01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-30-2006 10:23 AM
Saving amplitube inserts not working Guitarman002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-19-2004 09:12 PM
